Question about KitchenAid KSFS25FK Side by Side Refrigerator
How to clean the Drip Pan?
Our drip pan has some water in it, and a lot of crud sloshing around or stuck to the pan. However, there doesn?t appear to be any way to get it out to clean it. I am concerned about the drip pan getting smelly, or causing other health issues. (mosquitos, Legionaire?s Disease, etc?!) Does anyone have a solution? Martin mstep@greenval.com
  • Martin34 Aug 26, 2007
    Additional comment from original poster:
    This tray cannot be removed by simply taking off the bottom grill. The problem is that it is an odd shape, about 6 ? wide at the front, and then, about 6? or so back, it is about 10? wide. The door hinge and various hoses and wires, and a big part of the frame behind the left end of the grill block the try from coming out the front. Likewise, there is various hardware solidly mounted behind the tray which prevent it from coming out the back.
    I am close to concluding the a ?sponge-on-a-stick? may be the best approach.
  • 725 Answers
The Evaporator Tray should slide out after remove the bottom grille two clips hold it in...if you can't get it out use a wet shop vaccum with a rubber hose taped on the end ot it...let me know if you can get it.
Posted on Aug 26, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    hey do not come out easy. I have lifted the the Refrigerator up and put wooden block under them to get access to them. and slide them out from under... but you will always get some water and goo in the tray. as that is what it is designed for.
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
I cleaned out the water from the drip pan, cleaned out the pipe and it started working. Now the drip pan is full again and the furnace is not working
something has to come out the other end. where do you think the water is going? it has got to go outside, if not it will end up in the condensate tray and shut off your unit if you have a float switch.
Sep 03, 2012 | Goodman Heating & Cooling
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
My Hotpoint refrigerator drips water some times alittle and some times a lot I'm not sure where it comes from I have cleaned the rubber seal and made sure there is nothing keeping the freezer side from...
In most refrigerators there is a drip pan underneath that captures condensation and allows it to evaporate. Possibly your drip pan is missing or improperly installed so that the condensation is dripping onto the floor. Check your manual, or find one online. Usually you just have to remove the grill from the bottom of the fridge to get access to the drip pan.
Nov 19, 2017 | Hotpoint HSH22IFT Side by Side...
We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air...
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Sep 14, 2010 | Heating & Cooling
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water puddling under the frigerator
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
Jan 22, 2009 | Refrigerators
Terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Jan 05, 2009 | Maytag MSD2656G Side by Side Refrigerator
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
KitchenAid KSFS25FK Side by Side Refrigerator Logo
1,063 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
