Question about Honeywell Th5110d1006 Non-programmable Digital Thermostat
Honeywell TH5110D1003 not working
The thermostat does not respond to any changes I make to it. I have the cool setting to 78 and the heat setting to 75 and if I leave it on auto it will cool the zone down into the 60s until I go up in the attic and cut off the power to the circuit board. Is this a thermostat issue or do I need to replace my circuit board? If I turn on the heat it seems to respond to that at least the display says so but I can still feel cold air coming out if the vents.....help please
  • 95 Answers
SOURCE: My Honeywell T87F Thermostat doesn't
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Posted on Jun 10, 2008
Coldcut
  • 1554 Answers
SOURCE: our air conditioning was working
open the thermostat and look for batteries, 3 AA
http://www.heater-home.com/photos/2129-5b.jpg
http://www.heater-home.com/manuals/th8321u1006manual.pdf
Posted on Jun 13, 2008
koolbreezes
  • 540 Answers
SOURCE: I'm trying to turn on
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Posted on Sep 01, 2008
  • 104 Answers
SOURCE: Replace battery
Yes, the battery must be replaced. Gently lift or pull of cover, the battery compartment is there. Best of wishes.
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Th5110d1006 Non-programmable Digital Thermostat Logo
80 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
