Question about Dryers
Maytag maxima dryer
Dryer functioning but heat is not noticeably hot. Does the dryer sense that it is empty and not produce heat? Or???
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
RescueTech
  • 145 Answers
SOURCE: Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Posted on Dec 18, 2008
bozcro
  • 867 Answers
SOURCE: Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Posted on Jun 14, 2009
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 19, 2015 | Maytag Dryers
I have a Performa Maytag dryer it will sometimes turn on run a few seconds and then cut off and it will do this in consistently as I left it plugged in and left it on it was run and then cut off run and...
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 20, 2015 | Maytag Dryers
Dryer starts but shuts off after a few minutes
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 09, 2014 | Maytag Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
Instructions
Things You'll Need:
* Level
1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
.... The dryer runs but stopped producing heat.
there are two thermostates on this dryer, one is a self reseting thermostat on the gas tube and the other is a cycling thermostat. unplug the dryer and open it up and use a ohmeter to test the thermostats located at the bottom of the dryer. if they test ok the cats eye that senses the flam is bad or needs cleaning.
Aug 15, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
196 people viewed this question
Top Dryers Experts
