Question about Plumbing
Shallow well pump is always running
Using shallow well pump with a 1,000 gallon water tank, until existing well is "clean-out" and new submersible pump replaced. The well has been producing very iron/mudd water ever since a pump was pounded down into well after failure to remove. we go throygh a new pump every 2 years since. That was 7 years ago. Could the lining of the well be destroyed therefore explaining the iron/mudd water? Will "cleaning-out" the well fix this problem? How does one clean-out a well?
  • paul
    paul Jun 02, 2017
    Description of your well would help. The info I posted was for a 6" steel well casing. We have well cameras to identify problems.
    If you have a 6" well, take a look at the well casing,near the ground surface to see if you can spot a difference in color on the steel casing,then indicating the rise of the well casing cause by the frost. If you see this, all that will be required is the re-drivi g if we'll casing. And if this is the case, you might want to line the exterior of well casing with styrofoam am to a 4 ft depth to alleviate a reoccurring in the future
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
By the sounds of this, it looks like ur well casing may have heavef out of its rock seal with frost. The way I clean wells us I use a 160 cuft per minute compressor and run a 1" plastic pipe to bottom of well. I run air in cycles of approx 10 minutes on and 10 minutes off.I do this until I run out of water or water clears up. I repeat this for almost 6 hrs or longer.
Most likely this problem was caused by Shittu g workmanship driller
Posted on Jun 02, 2017
    Top Expert:
  • 50,033 Answers
Call the borers for ideas on how to fix as they are the experts
I have hear that sometimes a small explosive is detonated at the bottom of the bore to help clear silt build up but again , talk with the experts in the area
probably cheaper to sink a new bore enclose by and encase it with heavy plastic tubing rather that steel casing as it will not rust and cause problems
Posted on May 25, 2017
  • 18 Answers
SOURCE: mold in water reservoir
Run a couple of cycles of white vinegar through the iron allowing it to steam out. The odor may not be the most pleasant but it will clean out the mold as well as any build up that accumulates on the elements. Make sure you run two more cycles of just plain water through the iron on some scrap fablic or an old towel as any of the loose debris will come through the steam holes. After doing this you will find that it runs smoother than ever!
Posted on Aug 04, 2008
  • 3 Answers
SOURCE: Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Posted on Dec 20, 2008
SOURCE: Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Posted on Feb 04, 2009
  • 85 Answers
SOURCE: Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Posted on Feb 26, 2009
SOURCE: water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Posted on Aug 07, 2009
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Do I have to hook my tank to draw water from my well?
A bladder tank is designed to give a certain amount of gallons of "draw down" before the pump turns on. The pump will work with or without a bladder tank but will come on every time water is used. Well pumps (Jet or submersible) can run for extended periods of time without causing harm to the pump, but a pump that turns on and off constantly will eventually burn out because it is so hard on the pump.
Jet pumps need to keep "head pressure" to efficiently create the vacuum necessary to draw water from the drop pipe, this is partially what a well tank does.
RJ
Feb 12, 2011 | Flotec Corrosion Resistant Shallow Well...
Installed a new jet pump for shallow well (gravity feed to pump) - used old pressure tank - after about 4 months pump began kicking on and off constantly when in use - troubleshooting guide suggested it...
The pressure tank must have a certain amount of air in it so pump doesn't cycle as you say. The new pressure tanks have a bladder that separates air from water and keeps the pump from cycling so much. Make sure your pressure switch on the pump is OK--ie doesn't have burned contacts!
Mar 01, 2010 | Flotec Corrosion Resistant Shallow Well...
NO water pressure
It sounds like our pump is not priming, or is losing its prime (bad foot valve maybe?). There may also be a blockage on tank outline from some sort of debris that washed out of tank during install.
Nov 02, 2009 | Dyson Flowcheck CRO1 Front Load Washer
I have a 1 hp ace pump on a 30 gallon bladder tank the pressure switch keeps clicking off and on until the switch burns up have replaced 4 times in 2 months have adjusted switch until pressure is very low...
There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off.
Aug 30, 2009 | ACE JET PUMP For shallow well
Ive got a shallow jet pump model sd510 it runs all the time and it pumps the water from our holding tank to sump pit it runs about 250-300 gallons through to the sump pit ive replaced the pressure switch...
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Jan 04, 2009 | Plumbing
Plumbing Logo
526 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
