Question about GE Heating & Cooling
Model numbers AEH12AQW1
I BOUGHT THE UNIT, NEW, 1 YEAR AGO, IT WILL NOT GET COLD. THE COMPRESSOR SOUNDS LIKE IT'S COMING ON BUT THE AIR STILL BLOWS HOT. ANY SUGGESTIONS
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
  • 11 Answers
SOURCE: Duo Therm 13.5K Won't blow cold air?
needs freon. valve must be installed on unit in order to charge. if you know nothig about freon, call a repairman. Check craigslist.com
Posted on May 08, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 400 Answers
SOURCE: Compressor not turning on, no cold air
you need new capcitor in your A/C and do also use , if can the (Stabilizer) for coolest performance.... thank you
Posted on Jun 30, 2009
My window unit is not blowing cold air. Ive used it a handful of times and it never got cold. How do i fix this?
There are very many possible causes. You do not indicate your model number, but many units take a few minutes before the compressor comes on. If the compressor is not coming on (a low rumble sound, NOT the fan), you'll get no cooling. If the compressor is coming on, and you still get no cooling, it is likely your unit needs a recharge. Things to check: Is the thermostat set lower than the room temperature? Is the unit set to "fan only"? I hope this helps lead you to the problem and a solution.
May 09, 2014 | Heating & Cooling
I bought a may tag fridge 2 years ago model mb1956kes every 15 minutes my frige makes a ticking sound the sound last for 10 second
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Maytag Refrigerators
Please advise heating/cooling capacity for carrier quietline air conditioner vertical through wall model 25 years old model number unknown Thanks
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Mar 06, 2011 | Heating & Cooling
Air conditioner compressor seems to quit after 1 to 2 hours driving-blower stll runs, but cold air stops green compressor lite is still on, but no cold air-turn off ac for 20 to 30 minutus, comes back on...
Sounds like the air gap on the compressor clutch is to wide, when the compressor turns off to recycle the electromagnet on the clutch is not strong enough to pull the air gap and lock up compressor. The air gap is adjustable and should be checked.
Jul 26, 2017 | 1994 Toyota Camry
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Hi, I bought a used Air Ace air compressor. 5 Peak HP, 26 gallon tank. I need a manual for this and can't find one anywhere. Thanks
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Jan 14, 2010 | Air Tools & Compressors
New outside compressor 4 ton Ruud 13 seer unit.
Sounds like a compressor needs to be replaced. You will need a service tech to make sure of it. Sometimes the compressor can work for a long time that way. Check your warranty. Usually compressors will have longer warranty on it.
Jul 25, 2009 | Heating & Cooling
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
Jul 06, 2009 | Heating & Cooling
American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Jun 28, 2009 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
