Question about ViewSonic Office Equipment & Supplies
Computer screen on, Projector off
What do I need to do, if I do not want to take the cables off between Computer and ViewSonic - I want to leave them all connected. But when I turn the ViewSonic off, my computer screen turns off, too. Is there a setting where I can turn the Projector off, without losing my computer screen view? Thanks so much for your help
    Problem Solver:
  • 11 Answers
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Posted on Jul 09, 2013
  • 146 Answers
SOURCE: Loses the computer connection and just keeps searching
check connections to the computer, if USB connection, try another USB cable.
Posted on Jan 05, 2008
Marrie
  • 563 Answers
SOURCE: proxima ultralight projector won't project when I hook it up to my PC
Just get your PC settings right and Bob's your uncle
Posted on Apr 01, 2008
msuhelk
  • 106 Answers
SOURCE: can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Posted on Apr 14, 2008
SOURCE: VIEW SONIC PROJECTOR IS NOT STARTING UP
Sounds like it needs a new bulb
Posted on May 05, 2009
  • 269 Answers
SOURCE: Hi,I have a Proxima desktop projector that I have
right click on your desk top and check the display settings.
Posted on May 26, 2010
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
The projector shows slides as purple but computer has the right colours?
Check your cable...you are missing one of the primary colors. you could have a bent/broken pin on either the projector port or the cable or laptop port. this would be the VGA connection.
Jun 06, 2010 | ViewSonic PJ501 Multimedia Projector
My projector will not read from any computer. I
On a laptop you have to activate the VGA output with a key combination, usually Fn & F3. The appropriate F-key will have a symbol of a monitor on it.
You may also need to change the screen resolution to a smaller size to suit the projector.
Apr 12, 2010 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Projector will not detect a Dell computer
Computers do not generally send an RGB signal, you should be connected via a VGA cable between the projector and the computer. The input menu on the projector should be set to VGA. The output of the computer should be equal or lower to the maximum resolution of the projector.
Jan 29, 2010 | ViewSonic PJ551 Multimedia Projector
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top...
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Jun 02, 2017 | Televison & Video
135 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
