Question about Hitachi 55FX48B 55" Rear Projection Television
Wont power on
The tv wont power on I opened up the back and once the tv is plugged in led D964, D966, D922 and D947 light up green immediatly with led D912 glowing a constant red. second later D946 lights up there is a little buzzing sound and all the led's go out except D912 which begins to glow red in 1 second intervals. what does this mean?
    Genius:
  • 1,153 Answers
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Posted on Aug 26, 2007
SOURCE:
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
HITACHI 50ux10b rear projection TVfrom about 1993
Hello repko,
This looks like a problem related to your High Voltage Protection circuit. This circuit shuts the TV down when it senses a high current condition (a short in a vital circuit). It may not involve extensive repairs, but it will involve some repair work. I can give you a better diagnosis if you do a few things for me.
1) unplug the TV and take the lower rear panel off
2) look at the back of the panel or in the TV for a chart showing you the diagnostic LEDs
3) Look at see if LED D912 is red or not (this may differ in your model, if so write down the numbers of all the diagnostic LEDs and there condition on or off red or green.
4)post these in a reply to this topic.
Once this is done I'll be able to give you some idea of how extensive this may be.
Thank you,
I hope this helps,
Shuttle83
Nov 20, 2008 | Televison & Video
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Jan 04, 2008 | Hitachi 60SBX78B 60" Rear Projection...
No Picture no sound on a Hitachi Rear Projection
if the 120v never comes up, check e994 as it is probably open, and either the blue horizontal retrace cap infront of the h-out transistor is burnt/shorted or transistor could be.
Aug 04, 2007 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
