I was on my laptop and it just turn off with out warring. It was plugged up with power to it please help
  • 27,725 Answers
When laptops shut down without being prompted, this typically indicates that the unit is overheating, has a malfunctioning battery or requires a software or BIOS update.
While isolating the problem can be time-consuming, correcting the problem is simple.
Check for BIOS updates on the laptop manufacturer's website.
Check for operating-system updates.
Make sure that there aren't any obstructions to the air vents.
These will cause overheating and make the laptop shut down.
Remove the laptop battery, open all hatches and blow out any areas you have access to with compressed air.
This should dislodge any obstructions.
Retrain the battery, which may have lost its ability to hold a complete charge.
Unplug the laptop and use the battery until it runs out.
Once dead, plug the laptop in, turn it off and recharge the battery in full.
This may take at least 8 to 12 hours.
Repeat this process at least three times.
Check to make sure that your fan is working.
http://www.daileyint.com/hmdpc/overheat.htm
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
Could even be a virus or malware
Download and install at least one of these all free depending on your operating system
http://spybot-search-destroy.soft32.com/
Freeware detect and remove a multitude of adware files and modules.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
The hardware that you are trying to access is damaged or failing.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field.
In the context of computing, capacitors are used to block the direct current being circulated around the motherboard.
A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes.
Computer Problems
When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time.
The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images.
Identifying a Bad Capacitor
To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard.
A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of size and placement.
Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base.
Prevention
Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity.
However, some capacitors prematurely fail due to faulty work on the part of the manufacturer.
If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer.
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
Capacitor replacement
http://www.youtube.com/watch?v=s0Pn2tEjY04
How to check a capacitor
http://www.youtube.com/watch?v=U4tnHA0phcc
Replacing a leaking capacitor
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Jul 10, 2013
Toshiba L750D Laptop won't turn on, no power light nothing,
Could be a faulty power supply. Try getting a universal replacement and see if that works. Take the laptop to a computer store and see if they have one for you to try before you buy.
Sep 17, 2014 | Toshiba Computers & Internet
HP Pro4730s won't start
Hello arielconda,
This sounds like a problem with either:
1. The power supply in the laptop where the adaptor plugs into
2. a bad power adaptor.
If it is #2, try running on only battery power and see if it will come on. If it is #1, the motherboard will need to be replaced.
I hope that helps and good luck!
cf122d1a-fe84-4e15-8ade-8265b952ff1b.jpg 1284ec34-d9a8-4920-a4ff-3850b44b8dbd.png
Jan 30, 2014 | Computers & Internet
War Commander Windows 8
Its because Glitcheye programmed something into the last event that Windows 8 DOES NOT LIKE!
I can run a 7 year old pc running Vista on the same broadband and it works fine, plug in my Windows 8 laptop.....99%
Dec 27, 2013 | Softek International War Commander for...
How to unsuspend war commander
pls Unsuspend a War commander account
Nov 04, 2013 | youtube.com
Need serial key code for pc game men of war vietnam
Sir please help me because my games for the laptop the Men of war vietnam not open need the SERIAL NUMBER.. please give me an answer.thanks
Dec 03, 2011 | Video Game Consoles & Games
I cannot install Call of Duty: World at War on my PC
Hello
Thank you for using
FixYa for your problem
Delete the c:/program files/activision folder, Run a registry cleaner such as CCleaner, that should be able to remove all the invalid registry settings.
Now try again
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Activision Call of Duty - World at War for...
I was playing call of duty world at war xbox rrod
turn your xbox on and make sure it has the red rings then wrap a towel around thexbox make sure its completely covered leave it like that for an hour and the problem should be fixed
Jun 26, 2009 | Microsoft Xbox 360 Pro System Console
there have been scripting errors on COD:WaW where it has trouble with the graphics card. when you turn it on, does it say 'error code E74'? if so, you will need a new graphics card.
Jun 26, 2009 | Video Game Consoles & Games
Randomly Shuts Off
I think ur laptop goes to power saving mode.Right click on the desktop then choose personalize or properties if u have xp.
Then click on screen saver at the bottom click change power settings.Now if the power saver is checked then uncheck it and choose balanced in that change the timings as when it should sleep according to ur wish.
If u have any other problems please ask me..
Goodluck
Please don't forget to rate me as fixya..
Feb 06, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
180 people viewed this question
David Payne
David Payne
