Question about Vehicle Parts & Accessories
Nissan stanza cv joints - Vehicle Parts & Accessories
And the question a repair shop could not
answer---is ?
Posted on Jul 11, 2013
How to replace cv joints on a 1985 nissan stanza
It's better to buy a manual. find them at you local auto part store. There isn't enough space in here to explain. I've replaced stanza cv before, just be careful, For your safety use jack stands.
Feb 12, 2016 | 1985 Nissan Stanza
1987 nissan stanza 2.0 how to change front crankshaft seal
Remove number one plug and and turn it till its top dead center.
The timing mark will line up on the harmonic balancer.
Then it can be removed and changed, and the engine MUST not be turned when its apart.
if not to sure maybe ask your local mechanic for help?
Not an easy job
Good luck.......
Jan 19, 2014 | Vehicle Parts & Accessories
Does the 1988 Nissan Stanza have U-joints? The reason I ask is because when the car shifts it jolts. And when you put it in gear it jolts and vibrates. I looked under the car and I dont see a driveline. Is...
Hi, yes you have front wheel drive. The drive shafts are on each side going from the transaxle to the wheels. each axle has 2 constant velocity (CV) joints. This is a bit different than a U-joint but serves the same purpose. There are 2 indications of a worn out CV joint. Id the boot is torn, the CV will wear out due to dirt getting in. If you hear a popping noise when making a sharp turn, that is a worn our CV joint. If your boots are intact and there is no popping on turns, the odds are the problem is not with the joints but somewhere else in the drive train. Raise the car and turn the wheels by hand to see where the play is coming from. let us know if you have more questions, and thanks for using FixYa.
front wheel drive axle:
Jan 20, 2011 | 1988 Nissan Stanza
Where do i find the oil pan on a 1990 Nissan Stanza XE
this will be simple, I want you to jack up the drivers side of the car(like you have to change the tire), and get on the ground. I want you to look at the bottom of the engine. You will see to pans. the CV joints or shafts go into the transmission, You will see that pan. the other pan, under there, is the oil pan. It will have what looks like a bolt sticking out. that is the drain plug. The bolts holding the pan are I believe an 11 or 12 mm. bolts. hope this helps, if dropping the pan, let me know, I'll help if you need it.
Jan 08, 2011 | 1990 Nissan Stanza
Makes a growling sound from the right passenger side especially when you make a right turn.
Sounds like a wheel bearing or possibly a cv joint. If the noise gets louder the faster you get it's a wheelbearing if it only does it going round tight corners it's probably a cv joint
Oct 04, 2010 | 1990 Nissan Stanza
Cv shaft replace
This is usually the same on all front wheel drive cars..
Remove the wheel
Remove the brake caliper
Remove the brake rotor
Remove the spindle nut
Remove the wheel bearing assembly (usually 3 bolts)
-The next step may be optional, depends on the car-
Unbolt the lower ball joint (under the A-frame, some are riveted, if so, drill them out and chisel or just chisel them off with a metal chisel, sometimes you can cut the rivet heads off with a sawzall then pry it apart from the a-frame)
Pull the wheel bearing assembly from the spindle of the CV half shaft.
(Sometimes you need a wheel puller)
Once its loose, all you have to do it yank it out, and push the new one in. Make sure the new one pops in and is seated firmly.
Reverse steps for re-assembly. If you took the ball joint loose and it was riveted, use hardened steel bolts and nuts with lock washers to replace it, or buy a new ball joint, they aren't that expensive and it will come with bolts.
Good luck
May 09, 2010 | 1992 Nissan Stanza
The fuel pump, CV joints, plugs and wires all need replaced
I love my Stanzas.. Years ahead in design .. Drove the girlfriends new 2009 Dodge Calibre today and amazes me that all the column stalk controls are almost the same as my 1990 GXE ..
The good news is you don't have to drop the gas tank !
Just remove the upper portion of the back seat for access to the fuel pump and the sending unit : )
May 03, 2009 | 1991 Nissan Stanza
2000 nissan altima
your cv joint is bad. Instead of fixing the cv joint it is actually easier and cheaper to have or replace the entire axle your self. Because it comes with a cv joint and you get a new axle also.
Feb 02, 2009 | 2002 Nissan Altima
How to replace front wheel bearings and CV joints on a 1991 Nissan stanza
I can tell you on a 93 Altima that you have remove the entire wheel knuckle and press it out from the rear. Yeah, the knuckle, remove the strut tower bolts, drive train ( which can be lighty pressed out ), caliper and bracket, and remove the ball joint. There's a snap ring at the back of the wheel knuckle that holds the bearing, then press it out with a socket and a table vice or something to that effect. By the way the going commercial rate if you take it to a shop and have them do it starts at $150 for labor. Worth it, oh yeah.
Jul 24, 2008 | Nissan Stanza Cars & Trucks
AUTOMATIC TRANSMISSION WON´T MOVE
That trans is an RE4FO2A or V and check the fluid level,if the fluid level is good,check the axles to make sure they are seated all the way in the trans,and that the axle's CV joints aren't broken.Other than that,likely an internal problem with the forward clutches,torque convertor,or pump assembly.
Jul 08, 2008 | 1992 Nissan Stanza
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
