Question about Nikon Cameras
Cloudy screen the screen is cloudy and the picture is cloudy as well and it was not dropped
    New Friend:
It's possible that you have moisture on the inside of your camera, causing the sensor to fog up. It is also possible that you have fog on your lens as well. I have had cloudy images with my Nikon when it fogged up inside. The best thing to do is to make sure it dries out. This usually solves itself so long as you are in a dry location, but if not I would take your camera to a local repair shop to have it looked at and fixed. It really does sound like a moisture issue however. Do NOT dry your camera using heat or anything! If it doesn't dry on it's own, take it to a pro to get it fixed.
Posted on Jul 09, 2013
I have a 1998 Mitsubishi VS 60603/ 873G projection television receiver. the picture is not sharp anymore, appears cloudy, what is the problem?
Mitsubishi Electric Customer Phone Number Shortest Wait Best Support
How to Fix Cloudy Spots in LCD TV Screens eHow
Dec 16, 2014 | Mitsubishi Televison & Video
CLOUDY MACBOOK PRO SCREEN
screen probably needs replacing. There are no major known symptoms for cloudiness in macbook screens.
Mar 11, 2014 | Apple MacBook Pro Notebook
Manual for cubot p9
I have dropped my phone. The screen looks cloudy but still works. Do i need a new screen?
Dec 12, 2013 | ahappydeal CUBOT M6589S Android 4.2 3G...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Tatung plasma has cloudy screen. In and out seems to depend on backround color if picture is bad or not
That was the first generation, I would invest in another set considering the age and parts availability.
Apr 29, 2009 | Televison & Video
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Cloudy LCD
I think camera screen (LCD) is broken thats why you getting image as cloudy.
Jun 07, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Cameras Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
