Question about Bosch Clothes Washer Drain Gutter - 436479
Changing drain gutter Bosch 300 vision series washer
My Bosch 300 vision series washer started leaking out of the bottom right corner. The internal drain tube was cracked. I have ordered the replacement and removed the original drain gutter that connects to the external drain. But I am having a hard time removing the end that connects to the pump filter. It does not attach via a clamp but seems that it should turn and pull out. I have a hard time keeping the filter still while pulling on the drain gutter. Any suggestions of anything I may be doing incorrectly? Thanks!
barkencoa
  • 3463 Answers
SOURCE: Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
Posted on May 26, 2009
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
  • 10 Answers
SOURCE: Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
Posted on May 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Bosch 100 series won't drain or spin. How do I
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Apr 10, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Clothes Washer Drain Gutter - 436479 Logo
44 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
