A
Anonymous Posted on Jul 09, 2013
Smart code for Seiko smart label printer 1 1/8" x 3 1/2"
2 Related Answers
Anonymous
  • 232 Answers
  • Posted on Dec 12, 2009
SOURCE: how do I export from outlook to my seiko 440 smart printer
I'm not familiar with this printer but usually you export details as a .csv file which you can import in to most other software packages. If you need more help, please can give more detail. Thanks :)
Anonymous
  • Posted on Oct 24, 2011
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
How do I copy smart label printer files from desktop to laptop
I'm making the assumption that your SmartLabel printer was installed on your desktop computer and now you want to use the SmartLabel printer on your laptop. I'm also assuming your what the addresses from your desktop computer. That said...
Seiko has eliminated the software and driver support for all older models but you can download the needed software from a third party site. Here's a link to the very stable version 4.61
Seiko SLP 100 Free Driver Download
Make SURE your SmartLabel Printer is NOT Connected!
Set Up Steps
A. Install SmartLAbel Printer on your laptop
1) Copy the Seiko software onto your laptop and begin the installation program.
2) At the point were the installation program asks, connect your SmartLabel printer
3) If the SmartLabel program is open, close it
B. Retrieve your SmartLabel addresses from your desktop
1) Look for the SmartLabel directory under Program Files on your desktop computer
2) in this directory find a file named label.sll This file holds your SmartLabel 100 addresses.
3) Copy the file to a USB Stick
C. Transfer your labels to your new installation on your laptop
1) After installing your new SmartLabel printer on your laptop. Insert the USB Stick in your laptop
2) Copy the label.sll file into the new SmartLabel directory under Program Files.
3) Start the SmartLabel software and open a new label, you should see the addresses from your desktop computer
4) If you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Hope this helps
I need drivers for smart label printer pro
It would help if you had mentioned the Operating system and model number
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you may have to find your drivers on a third party site
SLP Related Drivers
SII Printers Drivers Download for Windows 7 8 XP Vista
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
I get an error 6 when I try to install my 240 to windows 8..1. What to do? I have been able to download a driver, but not the program to be installed.
I think you're out of luck. The latest driver I could find is 6.9.0.385, you can find it at the site below:
Smart Label Printer 200 420 overview Smart Label Printer 200 420 overview
This is a third party site, Seiko has removed all legacy support from their site. It was really only written for Windows Vista but people found it would work for Windows 7. Given the major structural changes in Windows 8.1 I don't think the legacy software will run in a Windows 8.1 environment
Smart Label Printer
If the answers above don't work check your AC adapter with a multimeter to confirm its output voltage. If the voltage is off by more than 1 volt you will need to replace your network driver
Seiko smart label printer 100 not printing
A censor within the printer probably needs cleaning.
WHERE CAN I GET THE DRIVER FOR THE SEIKO 220 SMART PRINTER
However, Seiko has deleted its legacy printer support so you will have to find your 220 drivers from a third party site. The 220 is pretty old so you need to use an older driver and it may not support newer operating systems
Seiko SLP 200 USB Driver Free Driver Download
Smart label 200 windows 7 driver
However, Seiko has deleted its legacy printer support so you will have to find your drivers on a third party site. I've included links to your drivers below:
Seiko SLP 420 Free Driver Download
SIISLP200 Drivers Download for Windows 7 8 XP Vista
Down load software smart label 200
How do I export from outlook to my seiko 440 smart printer
2helpful
2answers
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Top Seiko Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
