Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Filtered Ice and Water
Kenmore 106 72102100
Need part number for water fioter
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
I have an old Lady Kenmore washing machine that for the past couple of months now will not dispense water into the drum for a washing cycle. I have to manually fill up the tub with water and when the
You will need to replace the "water inlet valve". Se if you can get a part number off the valve. I will need that number or the complete model number to point you to the correct part.
Nov 27, 2012 | Washing Machines
Water tube to ice tray freezing up
Repairmantx is correct. Your dual water control valve is oozing water past the water valve that is used for the ice maker. Locate your model number and search for a dual water control valve if you have a water dispenser. Model numbers for Kenmore refrigerators looks like this example 325.326598. The first three numbers are the company that made your Kenmore refrigerator=> Kenmore - Who Made It for them?
I will be here should you have any questions, Thanks Sea Breeze
Feb 21, 2012 | Kenmore Side by Side Refrigerator
Need a water dispenser lever part number for a kenmore side by side model 253.52614200
Your part number is 241682202 also here is a link for you water paddle if this helps.
Good Luck
Oct 29, 2011 | Kenmore Side by Side Refrigerator
I need to know which is the Serial or part number of the Water filter of the Kenmore Refrigerator Mod 106.58953800 I need to replace it and get a great price Where?
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/9030/0046/046/Model-10658953800/0582/0165000?keySuffixId=&productTypeId=&searchModelNumber=10658953800&blt=06&subCompDesc=CABINET%20PARTS
Sep 05, 2010 | Kenmore Refrigerator Replacement Water...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My water dispenser does not work. I unscrewed the hose at the bottom of the door and there is water pressure there. Where should I be looking for the problem?
If pressure there it could mean anything may be possible. I need the Sears Model Number. If the water valve on rear of refrigerator does not open then water will not exit the dispenser. Sometimes water is frozen in the dispenser water container located inside the fresh food. Sears Numbers Look Like this (231.564897) for example
compartment. And sometimes it is the dispenser controls. I will need your Kenmore Model Number to tell you the part you need and to help you better. Thank You, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Jul 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Filtered Ice and Water Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
