Question about Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt
When I pull the trigger on my fimco sprayer only a small amount spurts our the the end and then it looses pressure and nothing. I release the trigger and pressure rebuilds to repeat the process over again. Same thing with the booms.
  • 63 Answers
SOURCE: LAWN SPRAYER PUMP WILL NOT SUCTION
Check the screen in the tank, it very well may be clogged.
Posted on May 03, 2009
SOURCE: I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Posted on Jun 06, 2009
SOURCE: I have a fimco pump on a 25 gallon sprayer. It is
at the end of the pump little square box with one pillpes head ,take it off and there is another screw in there turn it until it works,
Posted on Jun 09, 2009
  • 6 Answers
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Posted on Jul 24, 2009
SOURCE: Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Posted on Aug 09, 2009
Pumps
as soon as your finger is off the trigger
Jul 06, 2014 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
How do i release the pressure in tank?
If you turn the top (fill) handle it should release the pressure. Sometimes you have to also pull the trigger at the same time you turn the handle.
Jul 15, 2011 | Stanley Lawn and Garden Deluxe Steel...
I have a pressure washer that sputer when i pull the trigger. The moter sounds fine but i have pressure then nothing and i have pressure. Thank you Stu
how do i unclog the end of my pressure sprayer it works on low pressure but when i put it on high pressure nothing comes no water comes out.
May 03, 2011 | Karcher 2500 PSI Pressure Washer
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I'm loosing air on my 3hp air compressor, as soon as i pull that trigger on my compressor for about 2 second it looses air. No holes in the air hose nothing is wrong but just loosing air
Are you talking about the power switch or the trigger of an air tool?
If it is the power switch then how much air are you losing?
At start up most air compressors will lose a small amount of air through the unloader valve. As the compressor builds psi this valve will close. Once the max psi is reached the motor will shut off then a few seconds later the unloader valve will open again releasing the pressure in the cylinder. If your leak does not abate as psi builds you might need to replace your switch and valve.
Mar 26, 2009 | Air Tools & Compressors
Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt Logo
64 people viewed this question
Top Fimco Garden Experts
Jay Finke
Jay Finke
R.A. Ellis
R.A. Ellis
James Bayne
James Bayne
Level 1 Expert
Are you a Fimco Garden Expert? Answer questions, earn points and help others
