Question about Refrigerators
Age and capacity
Model # 363-9761585
What is the age and capacity of whirlpool washer wtw56008q0 serial # cu0821095
Hi sherry, This model is from 04/2007 and the capacity is 3.05 cubic feet.
Jun 09, 2017 | Whirlpool Washing Machines
Want to know the age of model 2917-D
Cant tell you the exact age, but they were made in the 1980's. If you have a serial number you can read them an tell you the week an year item was made. Something like T-100002788. Generally reads 27 wekk of 88 or could be 2 day of 7 month year 88. Each company did it a little different.
Jan 29, 2015 | Crock Pots & Slow Cookers
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
Whirlpool how to clean
If your washer was new in 1995 and has never been "drained and cleaned", it may be disintegrating from age.
Jan 01, 2014 | GE WSLS1500JWW 26" Top Loader Washer with...
House a/c unit capacity
This is not a website question. Please ask this question in a different category.
Jul 03, 2013 | Computers & Internet
Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
Jun 16, 2011 | Ruud UAKA037 Air Conditioner
I need to know what the towing capacity is for my 2000 chevy silverado half ton is?
Tow capacity for that vehicle is about 10.000 lbs (adjusted for wear and age). This number reflects max tow capacity with good tires (proper rating and good condition) with all suspension components in good used condition. The capacity of your tow hitch must also match your load and assumes proper trailer weight distribution and tongue weight.
For best results, I also recommend that you use a good quality synthetic gear lube in the differential and synthetic fluid in the transmission, as well as a trans cooler if not so equipped.
Jun 16, 2010 | 2000 Chevrolet Silverado
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
