Question about LG Washing Machines
Wf-t800 my washing machine prompt up error dE and stop automaticly
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
SOURCE: Dead LG WF-T8016TP washing machine
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Getting DE as error,next operation is hanged for WF-T7512 turbojet washing machine
DE is a drain error/
Your drain pump is blocked with lint or is defective.
Open the drain pump and clean it out.
Jun 11, 2011 | Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Lg washing machine WF TS 800 after selecting quick wash, machine will delay washing and says DE, washing will then stop.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
I have a WF-T700 automatic washing machine. My problem is that when I start it up, it automatically fills up the tub with water to a selected level and starts to wash but after about 4 - 5 seconds, it...
'DE' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 10, 2011 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
