U8668r35d motherboard floppy disk(c)fail (4)
    Brigadier General:
  • 3,400 Answers
Http://en.kioskea.net/faq/9008-floppy-disk-fail-40
read this and se if you can fix it.
Posted on Jul 09, 2013
Floppy disk fail (40) CMOS Checksum Error Defaults Loaded & Keyboard Unresponsive
Unplug the floppy drive cable from the motherboard and test.
Problem still there??
Check the leads of the 3 integrated circuits starting with the one directly to the right of the LAN connectors, and working down and to the left to the other integrated circuits.
The problem you are looking for is two leads shorted together or a lead broken by somebody who was careless with a card, and hit the IC during assembly.
There can also be a short caused by trash or loose components, but that is not as common.
Oct 06, 2015 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Floppy boot disk
Try setting the boot order in the BIOS to floppy drive first. If that does not work, try writing the floppy again, preferably to a different, new floppy disc in case that one is failing.
Oct 21, 2013 | Foxconn Computers & Internet
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Windows failed to load because the firmware (BIOS) is not ACPI compatible
please change the cbos battrey and set the bios optimize default
F10>yes.
hope it will help tou
dont forgate to vote me
Dec 01, 2010 | EliteGroup P4VXASD2 Motherboard
I always have failure to boot and have beep sounds. Already installed asus update v6.10.02, still shows overclocking failed on start up and requests to configure BIOS. My system includes: inno3D-FX5500...
1-Does your computer show any sign of response after power button press?
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up continuously after the mains power is connected? (Note: Both flashing and off are no good here)
Fix 1
(1) Isolate The power going into your system ( i.e. connect your system to the wall plug directly, without sharing the power with any other devices via power extension cable.)
(2) Check if the power supply and power cable functions correctly, and have the input of your power supply set to the correct position (either 100/110V or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You can store your BIOS into a floppy disk or a hard disk with FAT format. Then, you will be able to use AFUDOS to access the BIOS ROM file.
If it is not convenient for you to use DOS and AFUDOS, you can try to use EZ Flash. You can save the BIOS file into a flash disk then boot the system and enter BIOS, then you can update your BIOS by EZ Flash which is in the BIOS Tools page. Please load the default settings in BIOS after you have succeeded updating BIOS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | ASUS P5VDC-MX Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
MSI PM8M3 V motherboard with intel celeron D processor
If i am right, it's nothing serious, perhaps your Bios battery has been removed or insufficient voltage. You can replace the battery. Regarding "floppy disk fail", enter the Bios settings and disable the "floppy boot seek", this will fix your problem. Still problem? do let me know. Good luck Thanks for using FixYa.
May 31, 2010 | MSI PM8M3-V Motherboard
UPDATING BIOS... DISK BOOT FAILURE INSERT SYSTEM DISK
This happens because the boot process fails: either because in the boot order the floppy isn't mentioned (put it first) or the bootdisk isn't good.
BTW you should update the BIOS only if you have problems, like a new processor not being recognized.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Turn on and black screen says detecting primamy slave - none and
its could have various reson...
go to the bios and disable floppy drive then restart, if system start without any prob then may be your floppy drive is corrupt...
or check the wire are not loosed in your motherboard and floppy drive
Mar 29, 2009 | Intel Celeron -D 2.26Ghz Computer System...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
