I accidentally ran over the power cord for my filter pump and cut it in half. I would like to know how to splice them wires back together so that it works again.
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
SOURCE: power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
SOURCE: power cord was ran over by lawn mower and cut into
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
I tried to splice the cord back together matching the colors and when it was plugged in it didn't come on. The pump was on when the cord was run over. Is it possible something else could have happened?
