Question about Saeco Syntia Focus Automatic Espresso Machine - 104342
Saeco syntia focus water temperature adjustment
The coffee is not hot enough from the machine
  • 7 Answers
SOURCE: saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Posted on Jan 04, 2008
mirran
  • 515 Answers
SOURCE: Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Posted on Jul 18, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Posted on May 16, 2009
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
I have a Saeco syntia which I usually add beans, but have ground coffee and am not sure how much to add
If it's an espresso machine, you can find a manual at link. Use the scoop provided with the machine and add 1 scoop, no more than 2 scoops.
Visit the support page for your Saeco Syntia Super automatic espresso...
Oct 07, 2017 | Saeco Coffee Makers & Espresso Machines
Why after descaling my new Seaco Syntia coffee machine, it stops while brewing and it requires being primed over and over.
Syntia and Brera machines are made by Saeco. Brera is marketed under the brand name Gaggia (owned by Saeco).
The causes for this malfunction can be due to following in order as stated:
1- The machine was not descaled or it was descaled using products. that are labeled as descaler but they are not. After extended period of not descaling, one may have to use more than one cycle of descaling to remove accumulated depsits of Calcium in the water system.
2- The grind setting of coffee is too fine. Make it coarser by one notch toward coarser setting at a time.
3- The pump is losing its pumping pressure and not pudhing water through the coffee. Replace ULKA pump with an Invensys pump model CP3.
All fully automatic machines are convenient and make classic shots of espresso from bean to the cup at the push of a button. With this simplicity, owners forget its maintenance until machine stops working. Please pay attention to descaling every three months. No excuse is good enough.
Services Unlimited Inc Parts Guru
Oct 18, 2014 | Coffee Makers & Espresso Machines
Syntia swims in water in dreger drawer
Syntia is not set to "3 beans" amount or beans used are too large to create enough grounds to make a full 9 grams for a good puck .
The finger guard does not allow enough beans to grind in the timing of the software , common problem.... until the finger guard openings are made bigger or ... the software is re-programmed
Mar 05, 2014 | Saeco Syntia Espresso Machine & Coffee...
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia leaking out the bottom
Over pressure valve is broken, near the water pump , stop using it and get it fixed , or you may damage your Computer board
Nov 08, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Water tank parts for saeco syntia
Don't know where you are but www.dutchwest.co.uk in the UK supply the parts.
Mar 02, 2011 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia - error message 'problems with the water circuit'
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Jul 11, 2010 | Saeco Coffee Makers & Espresso Machines
Saeco Syntia Focus Automatic Espresso Machine - 104342 Logo
81 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
