Question about Kenmore 15899 Built-in Dishwasher
Will not turn on
Only half of the control panel is lighting up. It will not turn on
    Top Expert:
  • Kenmore Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#1#ixzz2YZQClslt
Posted on Jul 09, 2013
I turned power off to my Frigidaire when turned back on the freezer lights up and working but in the fridge the light is not working and control panel is not either
I appreciate your post, Robert!
Based off what you have described your Frigidaire refrigerator is not working on the fresh food side. It sounds like there may be a possible short in your control panel and that is why half of your refrigerator is not working. I would recommend performing a reset on your refrigerator and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help resolve your issue I would suggest contacting a professional technician for a proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this has been helpful. -Matt
Mar 12, 2015 | Frigidaire Refrigerators
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
Apr 03, 2014 | Mitsubishi WD-60735 Projection Television
Technika bellissimo oven not heating up
It is one of 4 things.
1. The heating element is out.
2. The dial temp control is bad
3. Only half of the breaker is on in the breaker box
4 If it is digital it could be your Control panel
In most cases we first check all breakers in the breaker panel if all is good. Then most likely one of your heating elements has burnt out. Try turning it to Broil to see if that one works if it does not work it is either your thermostat or control panel.
Apr 07, 2012 | Ovens
I have a Sub Zero 690 (June 1999 model). The frig size light switch went out. We popped it out to test to see if it had continuity (it didn't). We put it back in and planned to call service guy to...
remove the top light cover,hold in the other switch that's next to the light switch,the fan should turn on,it sounds like the fan isn't working,go back up top,remove the metal cover that's above the switches and see if you knocked the wire off of the fan switch.why can't you see the control panel?did it go out when you touched the light switch?
Sep 04, 2011 | Sub-Zero 690 Side by Side Refrigerator
Half of control panel lights/numbers are out
The control touch panel basically has partly burned out and so you would have to replace the whole panel.
Repairclinic.com should have a replacement, just use your model number to search for one.
Let me know how this works out for you.
Benjamin
Apr 30, 2010 | Frigidaire GLMB209D Microwave Oven
Why do only half the cluster lights work and the
this is most likely a short in your electrical system, on a newer Honda it can get expensive, i recommend taking your car to a foreign car doctor and have them analyze the problem
Good Luck...
Apr 13, 2010 | 2005 Honda Civic
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Hampton bay fan light half power
I had the same issue....Take the remote control and press the light button once...then hold down the light button for several seconds and they should slowly increase and/or decrease depending on the amount of time you hold the control button. Hope this helped.
Dec 12, 2008 | Hampton Bay 24002 Ceiling Fan
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kenmore 15899 Built-in Dishwasher Logo
55 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
