Question about Miele Dryers
Dryer keeps stopping cycle
My Miele Dryer keeps displaying "cooling down" and then shuts off. What is the solution?
  • Miele Master
  • 15,557 Answers
The most common cause of the error is lack of airflow. Check the exhaust output and see if it is restricted, you may have to check the venting in the building and unhook the dryer from it to check and see. If it runs unhooked from the exhaust system then it is a venting issue. IT could also be plugged lint screen, loose fan motor or obstructed fan. If it is not any of those then it is the thermal sensor or thermostat that is bad.
Posted on Jul 09, 2013
  • 87 Answers
SOURCE: dryer tripping electricity saftey switch
You probably have a shorted heating element.
Posted on Jun 08, 2007
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
SOURCE: dryer stops mid cycle-restarts when cooled
Get a new dryer, no matter how old! My dryer was doing the same thing, stopping mid cycle, we went to turn it back on last night and it ignited inside. Called 911, got the kids out, fire contained inside the dryer, but damage around. We just had minutes before the flames got to the walls! Now I'm trying to figure out the best way to approach Kenmore/Sears for such a faulty product that could of cost our lives and home! It's a Kenmore from Dec 2001. 9 years old should not start on fire!
Posted on Jun 16, 2010
  • 10 Answers
SOURCE: my dryer keeps shutting off mid cycle
OPEN THE DOOR AS SOON AS IT STOPS AND TEST THE TEMPERATURE IT COULD BE A DODGY THERMOSTAT
Posted on Oct 01, 2010
SOURCE: My Miele dryer keeps stopping
my miele dryer keeps stopping and flashing a red light between the locked pc light and the container light
Posted on May 07, 2011
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
WHY IS MY LG GAS DRYER NOT ADVANCING TO COOL DOWN CYCLE?
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 | LG Dryers
Error code 1477 on Miele T8322 Drier. What does this mean?
not sure bout the code. but it seems to indicate that the dryer is shutting down at certain heat levels. Thus u may have issues with ur cycling thermostat or thermal cut off or even ur venting and duct system.
Jan 28, 2015 | Miele Dryers
It will not stop beeping and i cant get it to cool down , it just keeps beeping and beeping.
hi,
shut the power off at the fuse panel let it cool down and reset breaker if it does it again you will have to call for service sounds like computer board issue
jm
Jan 01, 2010 | Miele H387B Stainless Steel Oven
My dryer shuts off before it is done with the drying cycle there is still time on the timer by the dryer quits
1 all dryers have a cool down cycle from 15 minuts down
if this is not the case does it stop at the same place everytime
if it does you need a new timer
Oct 08, 2009 | Dryers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer tripping electricity saftey switch
May 15, 2007 | Miele T1322C Electric Dryer
Dryers Logo
265 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
