Machine washes fine but when it gets to the spin cycle the dial just makes a clicking noise. The pump inside is working fine, drians the water out just wont spin the remainder from clothing
Belt is fine and it does agitate during the wash cycle. Was think the spin cycle of the dial is maybe had itBelt is fine and it does agitate during the wash cycle. Was think the spin cycle of the dial is maybe had it
I havn't checked that yet. Not really to sure how to get into that area between the drum and the tub thoughI havn't checked that yet. Not really to sure how to get into that area between the drum and the tub though
Checked that cant see anything jammed in there. Took agitater off earlier and cleaned out under it, was alot of lint and hair wrapped around the shaft. Thought maybe that was the prob but no. Just put another load thru and all is clean but still soaking wetChecked that cant see anything jammed in there. Took agitater off earlier and cleaned out under it, was alot of lint and hair wrapped around the shaft. Thought maybe that was the prob but no. Just put another load thru and all is clean but still soaking wet
Does the belt slip in the spin cycle? Something stuck between the drum and the tub?(sock)? I've had this happen, I didn't think a baby sock could stop the basket, but I was wrong.
Good Day, Your
washing machine is fully automatic?
the
washing cycle is normal?
if yes
do the same maybe it will help you.
for
the fully automatic washing machine mostly have drain pump, please check the
filter of your drain pump, how? remove the cup of your drain pump like a
ordinary cup, screw it clock wise or counter clock wise.
Remove
drain pump filter and clean it, some hair pins, cotton buds or coins or any
small item that coz of clog up.
if
your washing machine dont have drain pump ,but fully automatic check the drain
motor if running or not? how? open the back cover for top loader washing
machine only, select spin cycle and press start to see the drain motor running?
the drain motor is like a small box with small wire to pull the lever of the
drain to remove water inside, if the motor running or pull the lever of the
water pipe but water still inside the washing machine, remove the drain cup or
cover and clean it or check if have coin or cloth inside that coz of clog or
water stuck,
if the
drain pump or drain motor is weak this is will cause and long time draining or
totally not running the drain pump or drain motor and its cause of totally stop
the cycle of washing machine in rinse time or spin time, because all fully
automatic washing machine, after washing cycle the drain pump or drain motor
must be on, to remove water before start the next cycle. rinse or spin cycle.
Check to make sure that the filter in the pump is not clogged. Open the little door on the bottom and have a towel ready as there will be some water in the pump. Turn the dial slowly and let the water seep out. Pull out the dial and if you see any kind of debris, (lint, coins, etc..) Clean out all of this and put back into place and your machine will work fine. The reason for this is that the pump is designed to pump out all the water in an 8 min cycle if it exceeds the time limit the machine just stops. Hope this helps you out.
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water. All else is working fine. What part should be replaced?
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
It's noisy
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing
machines has been the under wire that may come out of small clothes. In the
washer they can get stuck in one of the inner basket holes and make a scrapping
noise, they can actually make there way into the pump and jam the pump, or make
a terrible noise when the pump is running. Grab a flash light and have a peek
inside the washer for this. Front load washers seem very common to this happen!
If the tiny cloth is showing signs of fraying, may be best not to wash it
in the washing machine, replace the cloth
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.======= It's noisy
Most noises
The problem most likely is something stuck in the water port of the drain pump. My machiine would not empty once and I found a 12 penny nail that had made its way from the drum though the drain line to the the pump, where it was wedged against the impellers that spins to draw out the water through the pump. The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump. Then do a better job checking your pockets.
Yeah i did check the belt when on spin and its just not moving at all
