How do you hook up solton by ketron lab programmer 24 s
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
Disk to fat converter
Your hard drive via USB connection did not power on your hard drive so your PC can't detect the drive. I don't believe the cause is your software. Try another UBS port, if that doesn't work power down your PC, connect your drive and boot up to see if the program detects the drive.
Nov 05, 2013 | Computers & Internet
Solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Apr 02, 2012 | Computers & Internet
I hooked up my honeywell rth111, the fan worked in the on position but not in auto. the furnace would not turn on at all. i have yellow, green, red, and white wires.
Possibly have the R and G crossed. Not sure, but your main 24 volts feed should go to R. If you get blower to run one of those 2 should be 24 v.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
How much?\creative labs usb sound blaster live 24
hi i have now offic7 and when i instsll my creative sound card no.580490 throw my oregnal cd. some part of program did'nt work like amixer etc.and alaway's i got this not on my computer . thes deveic not deteceted ?\r\npleas help me
May 21, 2010 | Creative Labs Sound Blaster Live! 24-bit...
I have the honeywelL RTH111 and also had an old thermostat with only two wires...... the manual says to just hook the wires to the same letter slots as it was in the old thermostat..... i did so but the...
Hook up the red wire to Rh (or Rc if they are jumped together) amd the white wire on W.
For thermostat terminal designation
R - 24 V power in
W - 24 V out to heat circuit
Y - 24 V out to cooling circuit
G - Fan relay
Hope this helps
Jan 21, 2010 | Honeywell Programmable Thermostat Heater
Dell dimension e520, speaker problems
Don't you have a CD that have the drivers needed? There should be a support section in the Dell website. I'm talking about the drivers of course, but, is everything hook up right?
Oct 13, 2009 | Creative Labs Inspire 5200 Computer...
Lost strings32.dll can't reload programme
Try to download the file from here and use it in your computer :
http://www.dlldll.com/downdll/6250.html
Hope that solve the problem
have a nice day
Please rate my answer
Oct 07, 2009 | Magix Audio cleaning lab 3.0 Full Version...
Hooking up new thermostat to new furnace
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
