Question about Panasonic PT-AX200U Projector
Yellow Power Indicator
My project shut its self off and the standby/on indicator turned yellow. Any ideas?
3 Suggested Answers
  • 4234 Answers
SOURCE: STANDBY MODE FOR PANASONIC FLATSCREEN TV TH-42HD6
Your TV is in protect mode. A problem was detected and the set shutdown. Is there a pattern to the blinking?
Dan
Posted on Mar 21, 2009
SOURCE: When you turn of the
Sounds like the lamp door is not secured in place. Try removing the lamp door and put in back in until it clicks.
Posted on Oct 09, 2011
My Panasonic. 27 inch triple play will not turn on and the on timer indicator keeps flashing yellow
The unit is either in shutdown (self protection) or the unit is not making it out of standby===someone needs to look at the power supply inside the unit to check voltages etc.
Dec 13, 2012 | Televison & Video
My ps3 has standby power on, but once you press the start button it turns on for a few seconds then switches off. also noticed that the light indicator for WLAN access indicator is on. the HDD access...
What you have is called YLOD, its a Chip Called GPU. It has been separated from your motherboard and causes to shut down to prevent any other damages. For a repair either send it to Sony or look to a local repair shop.
Thanks
www.1RepairStop.com
We Fix Everything
Sep 02, 2011 | Sony Playstation 3 (PS3) Console
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I got a replacement lamp, but red light still binks and there is no picture. Why?
hello if the lamp cover is not mounted securely the self -diagnostic funcation works and the power/standby indicator flashes for 3 times .when you've corrected it the power/standby indicator goes out and the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
Problem with my cruise control and ABS light on 03 Explorer
Anti-Lock Control —Vehicles Built After 03/2002 The 3-channel anti-lock brake system consists of the following components:
  • front wheel speed sensors
  • front wheel speed sensor rings
  • hydraulic control unit (HCU)
  • Anti-lock brake control module (ECU)
  • rear wheel speed sensor
  • rear wheel speed sensor rings
  • yellow anti-lock brake warning indicator
The 4-channel anti-lock brake system with traction control and stability assist system consists of the following components:
  • active brake booster with integral solenoid
  • brake booster release switch
  • stability assist module (ECU)
  • stability assist event indicator
  • lateral accelerometer
  • longitudinal accelerometer (4x4)
  • rear wheel speed sensors
  • steering wheel position sensor
  • yaw rate sensor
  • brake pressure transducer
  • traction control switch
I suspect the abs issue is causing the speed control not to work if it happened at the same time the cruise control stopped working. When the yellow ABS light comes on, it means the ABS is dactivated. You may have a faulty accelerometer which senses acceleration and yaw (side to side lean). I have not seen a bad one but you said it is sensitive to acceleration.
I would unplug it and see what happens. The connector should have a small tab to depress so you can pull the connector out.
Here is where it is:
Accelerometer Removal and Installation
  1. NOTE: The accelerometer is located under the center, rear passenger seat carpet. (I think you have to remove seat for access).
    Cut the carpeting along the perforations.
  1. Disconnect the electrical connector.
  1. Remove the nuts and remove the accelerometer.
Have dealer hook up tester and pull fault codes if you can't find an easy solution.
Some background info
  • A malfunction in the anti-lock brake system will cause the anti-lock brake control module to shut off or inhibit the system. However, normal power-assisted braking remains.
  • Malfunctions are indicated by the yellow ABS warning indicator in the instrument cluster.
  • The anti-lock brake system is self-monitoring. When the ignition switch is turned to the RUN position, the anti-lock brake control module will carry out a preliminary self-check on the anti-lock electrical system indicated by a three-second illumination of the yellow ABS warning indicator in the instrument cluster.
  • During vehicle operation, including normal and anti-lock braking, the anti-lock brake control module monitors all electrical anti-lock functions and some hydraulic operations.
  • Each time the vehicle is driven, as soon as vehicle speed reaches approximately 20 km/h (12mph), the anti-lock brake control module turns on the pump motor for approximately one-half second. At this time, a mechanical noise may be heard. This is a normal function of the self-check by the anti-lock brake control module.
  • Pedal pulsation coupled with noise while braking on loose gravel, bumps, wet or snowy roads is normal and indicates correct functioning of the anti-lock brake system.
  • Warning Lamp Indicator
    The anti-lock brake system (ABS) uses the yellow ABS warning indicator to alert the driver of a malfunctions in the ABS.
    The yellow ABS warning indicator will come on to warn the driver that the ABS has been turned off due to a symptom that exists in the ABS. Normal power assist braking remains but wheels can lock during a panic stop while the yellow ABS warning indicator is illuminated.
    Please report back, I am curious if that is what it is. Good luck
    Mar 03, 2009 | 2003 Ford Explorer
    Panasonic PT-AX200U Projector Logo
    37 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
