Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Picture is sepia like(just terrible)
I tried a dvd and it has the same sepia like picture.
    Problem Solver:
  • 10 Answers
This can be caused by two things, the first thing to do is disconnect the LVDS cable from going from mainboard to T-Con board the small board in the top middle of tv with a metal plate over it.
Clean the contacts of the cable and reattached the cable.
If picture still the same the T-Con board needs to be replaced.
In case of T-con Board replacement also check the power supply for bulging capacators because they can be the cause that the T-con board died.
Posted on Mar 08, 2014
Why does it show only a gray, ghostly image?
could be a setting in image settings there are a number of picture affects to choose from i.e sepia,negative,color tints etc, should be in picture editor
Aug 08, 2015 | Samsung Galaxy Note 3
HOW DO I FIX THE DISPLAY OF JVC TV? IT SHOWS PICTURE BUT THE COLOUR IS BAD. I HAVE DONE SEVERAL COLOUR SETTINGS WITH NO RESULT, DURING THE ADJUSTMENT, THE PICTURE CAN TURN TO SEPIA GREEN, SEPIA BLUE E
This sounds like a bad cable or connection. Swap out the cable with a known working one and see if that helps. Next, wiggle the cable nearest to where it connects to each device and see if that recreates the issue. If so, your cable either has bad ends or your device has bad ports/connectors.
Dec 06, 2014 | JVC Televison & Video
How do i take a black and white and sepia photo on olympus SP800UZ
The SP 800UZ doesn't have a black-and-white or sepia mode. You can convert a color picture to black-and-white or sepia by editing the picture on the camera. Full details are in the "Edit" section of the manual (page 38 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf
In general, you're better off converting to black-and-white or sepia using photo editing software on a computer rather than doing it on the camera. The computer will give you much better control over things like brightness and contrast.
Jul 08, 2011 | Olympus Cameras
Sony RDR-HXD560 with terrible picture quality
to get the part you need to go to the company to check what the problem is then if you will have to change circuit board you can get it right from them.
May 31, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Video and color.
The ViviCam does not record audio with video. You can add a soundtrack using video editing software on a computer, but not on the camera.
The 8025 does not have any provision for recording B&W pictures, sepia-toned or otherwise. You'll have much better control doing it on a computer, anyway.
Feb 16, 2010 | Vivitar ViviCam 8025 Digital Camera
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
DVD recorder isn't recording onto a blank disk in DVD format.
You just may have an issue with your DVD recorder. Happens.
Mar 29, 2017 | Televison & Video
When printing B&W pics, prints in color instead (sepia)
The b&W option from the driver are only applicable to documents. If you wanted to print B&W picture, you need to set it on the program that you are printing from.
Feb 02, 2008 | Epson RX595 Photo All-In-One Printer
Photoshop: how do I turn a color pic to sepia and leave certain part in color?
well i can suggest a very simple solution for problem. Follow the video to create a sepia http://video.about.com/graphicssoft/Sepia-tone-look-in-photoshop.htm
after that merge all the layers. Now add the original picture in you work and place it at the back of the Sepia Layer. Carefully erase the flower in the Sepia Layer and as you do this the flower from the original picture will show its original colors.
Please Rate Thanks
Jan 06, 2008 | Adobe Photoshop 7.0 (321115627)
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
