Question about Plumbing
Hydrostar model 95672
I own a pacific hydrostar electric power washer model#95672 1,400 PSI. The hose has come off completely from the handle and I cannot fix it.Do I just buy a hose with sprayer attached and if so, where do I get it?
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
  • 62 Answers
SOURCE: Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Posted on Jun 12, 2009
  • 22 Answers
SOURCE: husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Posted on Oct 07, 2009
SOURCE: Help! i have a pacific hydrostar 65078. Engine
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Posted on Nov 23, 2009
wireguy212
  • 1627 Answers
SOURCE: 2007 edge has windshield washer sprayer hose broken
You can pick up new splices or tee's at any parts store out of their repair kit,just take one with you when you go for reference.
Posted on Jan 28, 2010
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Apr 21, 2017 | Garden
How much oil does a pacific hydrostar in the pump their is no site glass pump 95618
There is no oil in this pump. When storing it long term , put some automotive antifreeze in it. Disconnect the water hose and tip the unit on its face to drain water out of the inlet fitting for short term non freezing times.
Aug 22, 2016 | Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Pacifichydrostar 1650 pump pulses when pulling the trigger
    It may be time to do mainatance to it. Look at: http://www.manualslib.com/manual/443079/Pacific-Hydrostar-1650-Psi.html?page=14
    for information on that. It is also possible you do not have enough water flow to the pump. Be sure your feed hose is not colapsing.
    Sep 21, 2013 | Plumbing
    Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
    dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
    Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
    Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
    Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
    Jul 09, 2011 | Plumbing
    Pacific Hydrostar 95618. pump oil?
    Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
    Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
    Engine oil comes half way up dip stick > engine oil 10W30
    Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
    Oct 13, 2010 | Garden
    My Karcher K9.8 electric pressure washer started
    Not Simple.
    I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
    May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
    Plumbing Logo
    118 people viewed this question
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
