Question about Texas Instruments TI-36X Pro Scientific Calculat
How to calculate the square root of a complex number?
I would like to know how to calculate the square root of a complex number and would also want to know how to insert a number in between an equation coz whenever I try doing it I end up deleting the ones that follow. And the usage of insert function is not such a good idea coz I gotta press shift and then insert for the damn thing
    Sergeant:
  • Texas Instru... Expert
  • 262 Answers
See captured images below
How to calculate the square root of a complex numb - 00a6ca8c-911c-4a34-a28d-c903414031b6.jpg
Posted on Jul 09, 2013
I dont know how to find the square root on my casio fx-300ES scientific calculator problem it wont let me square root 42 , when i square root 42 , 42 keeps coming and not the answer
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Sep 07, 2011 | Casio fx-300ES Calculator
Have TI30xIIS calculator. How do I find square root of a number. For example, the square root of 9. Where is the square root? I know 3 is the square root of 9, but how do I do this on calculator. ...
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
Feb 16, 2011 | Texas Instruments TI-30 XIIS Calculator
Does my ti-86 solve sq. root problems
Yes, your Ti 86 should solve square root problems. At the HOME screen press [CLEAR] [2nd] [x^2] which gives the (Square Root Symbol) to display at the Home screen. Then enter the number you want the square root of and close the bracket [ ) ] and, press the [ENTER] key.
You can even get the square root of complex numbers too. Select the correct complex format in the mode settings. For example: I'll do one in the rectangular form by enter a number as (a, b). I then will go to [2nd] [MODE] then [Arrow down] 3 times and make sure the RectC is highlighted and selected. Then quit out of the mode settings screen and enter [CLEAR] [2nd] [x^2] [ ( ] [9] [ , ] [ - ] [4] [ ) ] [ ) ] [ENTER], this displays the SQRT((9,-4)) equals (3, 2); The real part is 3 and the imaginary part 2.
Jan 09, 2011 | Texas Instruments TI-86 Calculator
The square root of -(49/64)
The square root of a negative number does not exist in lR, the set of real numbers.
In the set of Complex numbers the square root of -49/64 is (7/8)i, where i is the imaginary unit defined by i^2=-1.
Nov 23, 2010 | Texas Instruments TI-83 Plus Calculator
Is there an easy way to use vector mode to find the magnitude of a vector? I know you can just take the square root of the sum of the component squares, but it would be nice to have a shortcut.
If you're dealing with complex numbers, simply switch the view to polar coordinates. The length of the vector is the magnitude of the number. SHIFT MODE down-arrow 3 allows you to select between polar and rectangular coordinates.
Oct 07, 2010 | Casio FX-115ES Scientific Calculator
How would u get the caculater to do a square root problem like give i the real anwser
Turn calculator ON
If you see no icons, Press [MENU]
Use the arrow keys to move highlighting over RUN/MAT
Press EXE button.
In Run/MAT screen press [SHIFT][MENU] to access the (SETUP)
By default the mode is et to real as you see on screen capture below
In this mode if you press [SHIFT][X^2] to access the square root, then type in a negative number) you get the following message
To be able to operate on complex number you must set the calculator Compl mode to a+ib. You have to press F2(a+ib)
Press the F2 key corresponding to tab a+ib (complex)
Now if you enter what is on the next screen capture you get the correct result.
There is another way to enter complex numbers: the polar form. It corresponds to the F3 tab r<Theta
With angle set to degrees, you can enter complex numbers in r(r,theta) form (use [SHIFT][X,Theta,T] sequence to enter the wedge). Heis a sample.
I magnified the screen capture before pressing the Post it button, but I dot vouch that the system will respect my wishes. Sorry if pictures are too small for your confort.
May 24, 2010 | Casio FX-9860G Graphic Calculator
In complex number mode, how to get out?
"Is there anything that I can do about this to stop my answers being complex numbers when solving cubic equations?"
You are making an assumption that is unwarranted.Namely that a cubic equation must necessarily have 3 real roots. This is not the case.
Let your equation be
If coefficients are complex you should expect some complex roots. Right?
If the coefficients are REAL then depending on the discriminant
you can have three cases
DELTA positive : three distinct real roots
DELTA=0 , the equation has a multiple root and all roots are REAL
DELTA negative: the equation has ONE real root and 2 complex roots that are complex conjugate of each other.
It suffices to look at the Tartaglia/Cardano expressions of the roots to know that more often than not there is going to be complex roots.
May 05, 2010 | Casio CFX-9850G Plus Calculator
Need to know how to do squre roots step-by-step
type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
Sep 25, 2009 | Casio FX-300MS Calculator
How to factor?foil imaginary numberz
If you want to enter a complex number, simply put in as (a,b). For example, to enter the complex number 1+2i, enter
( 1 , 2 )
Feb 25, 2009 | Texas Instruments TI-85 Calculator
Texas Instruments TI-36X Pro Scientific Calculat Logo
122 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
