Question about Hotpoint Aquarius WF000 Front Load Washer
Door Lock As a result of my 1 year old son tampering with the buttons on the machine, the door has gone into a permanent lock mode. I have tried everything including leaving the machine for hours, re-washing, turning on/off and taking the plug out but nothing is curing the problem. Can anybody help with the solution. I don not have a manual either.
    Novelist:
    Champion:
  • 244 Answers
Right ther are 3 solutions that u can do 1)take your drain hose place it low to the ground into a bucket this should reset your pressure switchn if not goto solution 2 2mark were the cable is with black marker in case u need to put it back were it was if this does not work ull need to unplug your washer for this 1 undo the screws at the back top to take off your lid now if there is a cable to your motor u need to take a small black clip of were the cable goes into a holder u wont be able to c it ull have to feel for it once uve got this of click the cable up once and once done check the door to c if it will open now do this until it opens if not goto solution 3 3)if u feel do the front of the washer on the inside of the washer u need to be on the left hand side were the door latch goes into the catch by feeling down u will feel were the cable goes into this assembly godown slightly more and pull up the door should open on its own without having to push the switch let me know how it goes i am a hotpoint specialist m8
Posted on Aug 28, 2007
  • 38 Answers
What make is the machine
Posted on Aug 27, 2007
  • Anonymous Sep 04, 2007
    just turn off the CHILD LOCK the button that is marked child lock
    switch on the machine and hold the button in till the child in the seat belt goes out jobs a gooden good luck
SOURCE:
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Gorenje wa 72145 my son put washing up liquard in last night and the bubbles over flowed so i stoped the washer and empyed it. This morning iv gone to use it and f2 error comes up and wont work
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Jun 09, 2014 | Washing Machines
Golf gti left rear door locking system
it is probably your door lock has gone into safe mode.you need a new door lock.try using the lock/unlock button on your remote or on the drivers door button and gently tap the door handle with your hand while pressing the lock/unlock button,carefull not to dent your car.if that does not work,try disconnecting the cars battery for a few minutes,but note the vehicle might pick up fault codes which need a diagnostic machine to clear...good luck
Nov 09, 2009 | 2001 Volkswagen Golf
Door lock wont engage
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Jan 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Maytag MAH8700A
Joe, ds is a door lock malfunction. The door lock latch shows closed and the door switch shows open. Try this, unplug the unit for 60 seconds and see if the error comes back. If it does, with the power on press and hold the chime and xtra rinse pads together for 3 seconds. This will put it into the service mode. Once in the service mode press the chime button again to unlock and the temperature pad to lock. See if they operate. If still no luck you are going to have to do some tests on the door lock switch to see whats happening. You do have a 2 year warranty on these parts and being that it is only a year old, tell them to throw in the labor....Catriver...post back.
Dec 13, 2006 | Maytag MAH8700A Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
