Toshiba 620ku will not open dvd drawer - Televison & Video
    Top Expert:
  • 12,223 Answers
You must open the dvd and see if there are some belts crack, loose or bad and fix it. Replace any belt and lube slightly the carrier .test the motor if see are o.k or replace.
God bless you
Posted on Jul 09, 2013
What is difference between 620 and 620ku?
The 'ku' may designate in which (world) region it is to be used.
Jun 04, 2015 | Toshiba DVR620 DVD Recorder/VCR
On my laptop I can not open the DVD drawer to put film on some one help please
Press the button in the middle of the drawer to open it and put in the DVD.
Feb 15, 2015 | Toshiba Satellite C55D-A5201 AMD Dual-Core...
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Cannot get cd drawer to open. LCD says load, but
take the top cover off and have a look at the dvd,which has probably come off the tray. it is jammed for some reason
Aug 18, 2009 | Toshiba SD-K760 DVD Player
Toshiba satelllit a65 serial #64024039q
Look at it close and you will see a tiny hole. Put a gem clip or something that small into the hole and it should open. You can also right click the drive in ( my computer) to open it up.
Please rate me if this helps.
May 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
Open DVD Bose 3 2 1
Hello buivan, i wish i can make it bigger. but the file is too large to fit in. However, you can do the ff: if drawer bezel won't open by the eject button, do it manually. Turn over the console. you will see a slot underneath the front panel. use a small screwdriver and rapidly move the screwdriver toward the rear of the console.This will press in the built-in eject pin and cause the DVD drawer to open. Gently unclip the DVD drawer bezel from the front and lift it off. Remove 6 screws to open the console if you want to repair the DVD ROM made by Toshiba.
Good luck...siliconchip.
Apr 13, 2008 | Bose (321GS) System
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
