Question about Kenmore Brew 'n Wave 63992/63999 Microwave Oven
Coffee pot can i order a replacement pot online?
When putting the lid back on my coffee pot I screwed it on in the wrong position and I cannot get it off.
hi,
put your coffee pot in the oven on warm lowest setting for 15 minutes, take it out and try it.
jm
Apr 08, 2011 | Microwave Ovens
I would like to purchase a 9 cup corningware purcolator coffee pot
Click the link below:
Corningware coffee pot
Be CAREFULL they were recalled. See the information at the site below.
Corningware coffee pot recall
Good Luck.
Zeppelinx12
Mar 16, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
I recently purchased a 4-cup Farberware coffee pot (to replace one that served me well for over 30 years!!) The Model number is FCP with the initial G a few spaces after the FCP. I have had trouble...
Helen,
Fixya is does not sell parts or service, but rather helps answer questions about getting parts and service problems resolved.
You should contact the Farberware website for a replacement cord for your Coffee Pot. Click the "Customer Service" button on the left side of the page, or telephone 1-800-233-9054 for customer service if you'd prefer to speak with someone instead.
I hope this helps - and Happy Thanksgiving to you, too!
Nov 18, 2010 | Microwave Ovens
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
http://www.starbucks.com/customer-service
Good luck, and hope this helps.
Nov 09, 2010 | Microwave Ovens
My coffee pot on a kenmore brew and wave is missing a stop
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 27, 2009 | Kenmore Microwave Ovens
DO COFFEE POT AND MICROWAVES USE ELECT WHEN OFF (
Unless there is a clock, they use no current when turned off.
Apr 30, 2009 | General Electric Microwave Oven
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Replacement part
Sears Parts at http://www3.sears.com (yes the three is correct)
Oct 18, 2007 | Microwave Ovens
Kenmore Brew 'n Wave 63992/63999 Microwave Oven Logo
16 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
