Question about Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Green light on - screen on briefly, then goes black.
Have had this monitor for 10 yrs. I Love it, bought it through an AOL on line promotion for $99. it was way ahead of my time - now what has happened? Appreciate any guidance. If replacement is the only option - where is the best price? Thank you in advance. Debi
  • tayers007 Aug 24, 2008
    SAME ISSUE -- IF YOU KEEP TURNING IT ON AND OFF IT WILL EVENTUALLY HOLD THE SCREEN ON... JUST FRUSTATING.
    I REALLY DO LIKE THE MONITOR.
  • 63 Answers
Replacement is probably the only option at this point. It would cost more to fix than it would be worth new. Try going to: www.tigerdirect.com www.newegg.com They are usually running cheap specials on monitors.
Posted on Aug 27, 2007
SOURCE:
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
When computer off monitor displays orange light.when i turn computer on green light briefly on than goes out. Monitor remains black'
This is not always a problem with the monitor. It could also be caused by a faulty display card in your computer. Try plugging your monitor into a working computer to determine where the problem lies.
Best wishes,
Graemevm
Jun 08, 2010 | Computers & Internet
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site [email protected] www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Kogi l5qx-ta ko 15" Flat Panel LCD Monitor Logo
120 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
