Question about Measuring Tools & Sensors
Is .64oz greater or less than 1oz - Measuring Tools & Sensors
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
Less.
Posted on Jul 08, 2013
Is 0 greater or less than 8? Such a simple yet hard question
In Mathematics, zero is less than eight. On a number line where you have negative numbers to the left, zero in the middle, and positive numbers to the right, and number to the right of the other number is considered the greater number. That is, it is greater than any number to the left of it. This is the convention. It is as if more of something is coming into existence as you move to the right. This may defy the idea of the length of a vector on a graft but there you have it. Numbers to the right are considered "the greater."
Sep 01, 2017 | Hard Computers & Internet
A number greater than -5 but less than or equal to 5
Greater than -5, means infinitely close to -5, but greater than it, so it is on the right hand side of it. On a number line, we indicate this with an open circle at -5.
Less than or equal to 5 means 5 and everything less than 5. On a number line, we indicate this by drawing a circle at 5 and filling it in.
O------------------------------------•
Sorry, I couldn't find a filled in circle to be the same size as the capital o;)
Good luck,
Paul
Dec 08, 2016 | Office Equipment & Supplies
I need help on homework of greater than less than or equal than.
In mathematics, if there are 2 numbers being looked at as an inequality, the greater-than symbol usually goes in between the two and symbolizes that the first number is greater than the second number (For example: 4 > 2, or 102 > 100).
Greater-than sign - Wikipedia
https://en.wikipedia.org/wiki/Greater-than_sign greater than less than or equal than Google Search
Dec 01, 2016 | Computers & Internet
Does the symbols stand for greater than or less than
This is 'greater than' >, eg X is greater than 3......... X > 3
This is 'less than' <, eg Y is less than 3......... Y < 3
Jan 13, 2016 | The Learning Company Achieve! Math &...
What is the chocolate hurricane drink? I heard someone order one at a bar and am very curious.
Chocolate hurricane is a cocktail that contains:
1oz chocolate liqueur
1oz coconut rum
1oz orange juice
A splash of lemon juice.
Put in a cocktail shaker and mix well.
Feb 25, 2013 | Wine & Spirits
AC WILL NOT TURN ON WILL RUN BY USING SCAN TOOL
{: ) When an A/C mode is selected, the A/C control head or the A/C programmer supplies a 12 volt signal to the PCM A/C request input. The A/C compressor clutch relay is controlled by the PCM. The PCM provides a ground path for the A/C relay coil. When the A/C compressor relay is engaged battery voltage is supplied to the compressor clutch coil. The PCM will enable the A/C compressor clutch whenever the engine is running and the A/C has been requested unless one or more of the following conditions are present:
Throttle angle greater than 90 %.
• A/C head pressure greater than 414 psi (4.27 volts) or less than 34 psi (0.35 volt) (as determined by the A/C refrigerant pressure sensor). • Ignition 1 voltage below 10.5 volts. • Engine speed greater than 4500 RPM for longer than 5 seconds. • Engine speed greater then 5400 RPM for any amount of time. • ECT greater than 125°C (257°F). • IAT less than 5°C (41°F). • Throttle angle is greater than 90%. • A/C head pressure is greater than 414 psi (4.27 volts) or less than 34 psi (0.35 volt) (as determined by the A/C refrigerant pressure sensor). • Ignition 1 voltage is below 10.5 volts. • Engine speed is greater than 4500 RPM for longer than 5 seconds. • Engine speed is greater then 5400 RPM for any amount of time. • ECT is greater than 125°C (257°F). • IAT is less than 5°C (41°F). Any of the conditions described above will inhibit A/C compressor relay operation.
A scan tool can control a/c operation without regards to the prevailing parameters that can inhibit its functions. Remember that the scan tool is a very effective diagnostic tool.
In this case, the scan tool was able to control a/c, which is an indication that the PCM is communicating, and that circuit 459 going to the relay and then to the a/c compressor are normally functional. You need to check now if the sensor input signals are within the specified ranges.
Jul 06, 2011 | 1997 Chevrolet Venture
Solution for "in math what
9>2 (Nine is greater than 2) 1<5 (one is less than 5) 5>1 (five is greater than 1)
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Jun 21, 2011 | Computers & Internet
How many scoops of coffee and water do you use for 36cups?
All depends on how you like your coffee, And the size of cups you are using.
The standard is: 64oz. of water and 2oz to 3oz of coffee for 12 cups, That is about 5 to 6oz.of coffee per cup.
If you want a strong cup of coffee use 1.5 gal. of water and 9oz of coffee for 36 cups. If NOT use more water and less coffee.
REMEMBER, Don't let the coffee sit in your coffee brewer for long time.
Jan 13, 2011 | Faberware Coffee Makers & Espresso...
How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Aug 15, 2009 | Bloomfield 8742 iced tea brewer, 3 gallon
Measuring Tools & Sensors Logo
18 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
