Question about Refrigerators
Plhs269zdb9 How TO change Dispenser Power Board PartSelect Number PS1526485
Why doesn't dispenser control board work?
the main board could have failed and also caused the dispenser board to not work. What is the model number of the refrigerator?
APPLIANCE 911
Jan 21, 2016 | Refrigerators
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
How to change the light bulb on the ice dispenser in the door?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
First - Make sure the dispenser light switch is turned off. Now, that you have broken the bulb it is like having a bare 110 volt hot wire.
I recommend that for safety purposes you do not use either the ice or water dispenser and well as the chance of condensate from warm outside air getting into the electrical and burning out the control board or harnesses.
Get some electrical tape. Turn power off to the refrigerator at the breaker box or unplug the refrigerator. Then, tape over the broken bulb. Turn power back on to the refrigerator.
You may have a ice dispenser cup that you can remove or the dispenser frame for more ease of access.
You now may need a pair of needle nose pliers to remove the bulb.
You did not provide a model number so I can see exactly what you have. Your model number is on the inside of your fresh food section on a label on the upper inside wall.
May 10, 2015 | Kenmore Refrigerators
Kenmore Model 10650562990 side by side. Ice dispenser leaks air and allows ice to build up in dispenser. Which part contains the seal that closes dispenser.
The part number for the door seal is 2180353 you could purchase it at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE
Sep 16, 2011 | Refrigerators
Ice maker freezes but doesn't eject the ice
Check that the shute and door is not frozen shut. You can check the power to and from the dispenser switch with an ohmmeter, test-light, or voltmeter to make sure it is not faulty. You can get parts and manual at repairclinic.com or partselect.com
This is the two most common problems for this problem.
Other than the dispenser motor itself which can become faulty. Check power to this as well.
Nov 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water from dispenser
As you have ICE then the most likely a fault with the water dispenser valve. It may also be a fault with the controller board. You can try resetting the Fridge Freezer by switching off the mains line power for approx 30 minutes and not opening the doors pr pressing any buttons during that time. Then turn the power back on and see if the fault has cleared. If not then you will need the valve or controller replaced.
Oct 15, 2009 | GE GSS20IEP Side by Side Refrigerator
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Low product light stays on
You can go to partselect.com and purchase a new switch for the low product. It mounts on the back of the dispensing rack, item number is 18 on the assembly diagram. It is also possible that the existing switch has become unplugged from the board by ice buildup.
Jan 25, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Dispenser
Do you have power to the control board (item 17 in the diagram)?http://www.partselect.com/Schematics/Maytag/AA58-16.gif
Dec 30, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
