SOURCE: Honda accord 07 making a highpitched squeaking noise in cold
That Squeeling is your Belt. You may need a New Belt Tensioner to keep it Tighter. As a Quick fix, Go to your Auto Parts Store and get a Can of Fan Belt Dressing and spray this on the Belt and it will be Quite for a while. Please Rate my Solution, I need all the Help I can Get! Thanks!
SOURCE: 25mph to 50 mph tire wobble
It could be a couple of things the tires could be out of balance and need rebalanced on the machine or it could of lost a weight from either the inside of rim or outside wherever your weights are located.
SOURCE: Engine knocking/vibration
A few different things could be causing this, most are internal engine components. First off, take your tires and have them balanced to make sure you didn't accidently fling off a tire weight when you hit a pothole. Next, if that is not it, either you have a blown head gasket, cracked rings, or bad rod/main bearings.
Multiple problems. Take it to a mechanic. If the car has high mileage, call the junk man.
