Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Toe out issues
I bought a Craftsman 26 hp, 54 inch deck mower 3 years ago. Model # 944.609310. From day one it has been a struggle to steer. Turns out that a design flaw is the culprit. The deck is suspended by the front axle bolt which through a stress chain reaction causes the frame to bend and front wheels to toe-out. It has been brought to my attention by a Sears repairman, an engineer and an auto mechanic that this is a design flaw. The Sears repairman said he and his colleagues have seem several of these with the same problem. Sears should have recalled the mowers. I am going to contact Sears and see what they are planning to do to satisfy this customer. Anyone else with this same problem?
3 Suggested Answers
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 6468 Answers
SOURCE: 26 hp 54 inch craftsman mower will not cramk over. sounds like turns over once than no more. replaced battery and same issue
try you and jump start the engine direct to the starter if you have a bad battery cable it will not carry the amps needed if still no luck remove the spark plugs to see how it cranks over if spins over fine you might have a bad compression release system on the cam shaft if fluid spits out the carb could be leaking into the engine
Posted on Jul 01, 2012
How to adjust toe-in
look at the tie rod ends . they are adjustable .
Oct 21, 2015 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Jun 29, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My belt keeps sliding off i have a 52 inch deck 3 blades . need diagram
Your owners manual should have a diagram. If you don't have the manual, you can download one here. You will just need the Craftsman model number of your machine.
http://www.searspartsdirect.com/partsdirect/product-types/Riding-mower-tractor-Parts
Mar 23, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Turns fine to the left but will not turn right past going straight.
check your steering linkage on the front side by that right hand wheel, is it bent or being restricted? Even check up and down on the steering wheel column itself.
Aug 13, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
How to change the drive belt
I'm unsure of your model number, but this may be of use, its a manual in PDF form.. You will need a version of adobe reader if you dont already have it.
Craftsman 26 HP, 54" Manual
Download adobe reader
Jun 09, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
