Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
The tv sound comes but there's no picture. Then after the red standby light blinks 10x's then the tv shuts off.
    Champion:
  • 247 Answers
Problem with str ic need replacement has an internal short need a tech to do it
Posted on Jul 11, 2013
ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
shbuckler
  • 126 Answers
SOURCE: sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Posted on Dec 24, 2008
ltfrc
  • 227 Answers
SOURCE: TV will not come on. TV standby light blinks nine times continuou
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Posted on Apr 17, 2009
  • 87 Answers
You need to call a Sony service center for this problem. It will cost you less in the long run.
Posted on May 23, 2009
  • 125 Answers
SOURCE: I have a 51 in. Sony model kp-51ws520. when I turn
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Posted on Mar 24, 2010
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
The tv does not turn on and standby light blinks a total of 10x
This is an akb problem, this means that one of three probible solutions,
1. one of your picture tubes have gone bad,
2. A driver ic on the neck module has gone bad.
3. you have a bad focus block.
no's 2 and 3 will cost around $200 to fix, No 1 will be very expensive about $500 to fix.
Sep 02, 2009 | Sony KP-51WS520 51" Rear Projection...
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Red light blinks 10x then powers down, help me!
Go to this link and scroll down for info of the ten blinks.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Will give you some info of what to do next.
Mike
Mar 26, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Dec 05, 2008 | Sony KP-51WS520 51" Rear Projection...
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Standby light blinking
How many blinks is the light blinking in between pauses?
Sep 24, 2007 | Sony KP-51WS520 51" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
