Question about Garden
Sputter black smoke
My honda lawn mower starts strong but smokes black then starts to run at a low power like its going to stall
    Sergeant:
  • 340 Answers
Austin I think you have to much oil in it. So much its's interferring with the air intake. Drain some oil and clean the air filter. When you have done this give it an hour to settle then run it for a bit to burn the residue of oil off. John
Posted on Jul 09, 2013
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
SOURCE: My lawn mower doesn't start and when it does, smoke comes out of exhaust
I used my mower two weeks ago. Now it won!t start, I check the air filter,change the gas, check the
spark plug and it was soaked with gas. I clean the plug and set the gap and it still won!t start. It
sound like it wants to start but it will not start.
please answer me fast
Thank you very much
Posted on Sep 17, 2008
  • 37 Answers
SOURCE: Heavy smoke when you first start the engine
Hi. sounds likes too much oil in engine or if you tilt the mower up&down or side to side.
if you need more help, just write again
Posted on Nov 21, 2008
SOURCE: Mower smoking and sputtering.
Sounds like the engine is getting flooded because the carburetor float needle is not seating. Let me know if this helps.donnyb60
Posted on Mar 23, 2009
SOURCE: I have a Craftsman 650 series lawn mower. It
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Posted on Mar 28, 2010
Honda pressure washer GCV160 5.5 HP started smoking while engine was running.
White smoke or black? White means the carburetor is flooding. Black smoke could mean a clogged air filter.
Sep 16, 2013 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
07 mtd yardsman mower with 13.5 tecumseh runs great untill engage mower , then dies down and blows black smoke
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
Jul 08, 2012 | Garden
Just bought a 10 year old lawn boy 2 cyl mower from my neighbor. He had not used it for 5 yrs (heart problems). I put the 2 cyl ashless oil into the gas like the instructins said 32/1 mix. That turned out...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helps
May 20, 2010 | RTO Lawn Boy 6.75hp Mower
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
Nov 17, 2009 | Craftsman Garden
MY Kawasaki FH500V commercial lawn mower engine won't start.
Try cleaning the throttle body. If it runs on carb-cleaner being sprayed into the intake then you have a fuel delivery problem, if not you'd be more inclined to more serious mechanical failure. I assume if you use it every day you do the regular oil changes, air filter cleaning, and air-cooling system cleaning, correct? Please indicate if you had a white smoke, blue smoke, or black smoke from the mower too. The motor spins freely when attempting to start, and just doesn't fire, correct?
-JMFT
Oct 01, 2009 | Toro Lawn Mower With Toro Power Tools
My 21 HP diesel zero turn mower starts blowing black smoke after running at higher throttle settings and temp gauge shows engine is warm. No air restrictions. New fuel filters. smooth running when cool or...
Looks like you've got a good idea on what makes diesels smoke, so I'm sure you know that black smoke is almost always from too much fuel for the air that's going in. So it can be too much fuel or too little air. If your filters are good, the next things to check are the fuel pressure and the injectors.
I know diesels, but I don't have any specific experience with lawn mowers (kubota?). Since it stalls eventually, it sounds like it's not a single cylinder (although not for sure) so I'd check injector pump first.
Sep 28, 2009 | Garden
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
