Question about Lands Phones
RCA visys dect 6.0 Line 2's light is lit and no dial tone. All handset are in off mode. Only Line 1 is available
  • 5,221 Answers
Are the phone cables correctly connected to the base unit? Try a new cable for Line 2, if you have separate L1 and L2 jacks. (If the lines are integrated in one jack, make sure to use a 4-conductor RJ11 cord.) I assume the service hasn't been cancelled for line 2 and that you are at a wall plate with both lines.
If you have separate jacks, I like to use a different phone to check the jack. (A simple old fashioned corded, single-line phone is useful to check for a dial tone.) Try checking Line 2 at another jack, if you have one.
If you do not have a dial tone, find where your service comes in. Open the box and look at the terminals. If you are lucky, you have an RJ11 port. Plug in your test phone in to the Line 2 connection and listen for a dial tone. If there is no dial tone, contact your telephone company. They will fix an outside line problem for free. (Mice and other things can damage the wiring. A lightning strike could damage a filter if you use the line for a high-speed internet connection.) If the terminal doesn't have an RJ-11 plug option, you will need to ask your telephone company to test the line.
If you recently had work done on the phone line, check for any wires that are loose. When we got our phone line upgraded to fiber optics, one of the telephone jack lines didn't get connected to the terminal in the new box. We found the wire behind the vinyl siding and got signal as soon as the wire was reconnected.)
If you have a dial tone at the box and no wires are obviously disconnected, you'll need to trace the wires inside to find a broken connection. If one jack worked for Line 2 and another didn't, check inside the wall plate. There are two wall-plate styles. The ones with a keystone jack needs the conductor wires pushed down into the correct slots. A punch-down tool is available from most hardware stores in the wiring section. The screw terminal type requires the individual wires to be stripped and then secured. The correct terminal positions are shown here: http://www.lanshack.com/wire_phone_jack.aspx . Otherwise, you need to trace the wires in the walls to find the break in the continuity. Your phone company will do this for you for a fee. If you have a line filter inside, try replacing it.
I hope this helps.
(I've called the phone company several times when we lost one line. Mice and lightning damage to the filter have both been culprits.)
Posted on Jul 08, 2013
SOURCE: Have dial tone but can't dial out
I just spoke to RCA and they said to unplug power and phone line and take out batteries, wait 5 minutes and plug everything back in, mine now works.
Posted on Apr 24, 2009
  • 53 Answers
SOURCE: i lost my manual and am trying to set up my rca
http://www.rca4business.com/products/pc/pdf/instruction-book/25450RE3.pdf
There you go.
Posted on Feb 01, 2010
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Posted on Feb 20, 2010
SOURCE: uniden dect6.0 handsets do not operate
I am writing for my Mum, who is 99. We live far apart, so it is a bit difficult to fix her problem. She had a new Uniden DECT 60 (?) installed in early July. It seemed to be working fine when we left her, but she says it only rings twice before going to voice mail. She says it has always been like that. How can we fix this for her even though we live at a distance?.
Posted on Aug 17, 2010
SOURCE: RCA ViSYS phone says "replace battery" but it doesn't have one
There is a battery box that holds 4 AAA batteries. It's down under. Not easy tospot but it's there. However, I added fresh batteries and it stil says replace battery. I'd like ot know how to turn off the message.
Posted on Sep 26, 2010
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
Why is line 1 line is red if it is not in use and line is dead
If line one is red then the phone is not seeing the dial tone for that line. I would replace the phone cord from the phone to the jack first. If no change have the jack tested to verify the line is working at that location.
Jul 21, 2014 | RCA ViSYS 2-Line Speakerphone
Searching for line 1 or 2
The system isn't seeing the dial tone for lines 1 or 2. Check the cords from the phone to the jack. If no change, have the jack tested to verify the lines are working at that jack.
May 26, 2014 | RCA ViSYS 2-Line Speakerphone
Speakerphone doesn't work
Possible. Check out your manual regarding speaker phone settings, etc.
Aug 29, 2017 | RCA ViSYS 2-Line Speakerphone
Phone keep initializing
I had the same problem (constant initializing with dropped lines, no dial tone, etc) with my RCA Visys 2-line phone (model 25205) after owning it about 3 months, and could not find a solution on the Web, so I called RCA customer service. They said this problem is not user-fixable and they gave me an RMA# to return it. They will send a replacement phone as soon as you fax the receipt, your name, problem with the phone, etc.. Then when you get the replacement phone you send them the bad phone.
Aug 31, 2010 | RCA ViSYS 2-Line Speakerphone
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
Apr 23, 2009 | RCA ViSYS 2-Line Speakerphone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
