Question about Refrigerators
Kenmore Refigerator My frig will not get cold anymore. It'll get cool, and the top will still freeze but the bottom will only get cool. I have it set to the recommended settings. My babies milk will spoil if i leave it in the frig. That's how cool it will only get.
  • 1 more comment
  • FredinGB Dec 17, 2007
    My freezer continues to frost up and the refrigerater will not cool. I unload the freezer, and with a hair-dryer, I remove all of the frost from the evaporator and surounding areas. After a week or two, I have the same problem.
  • Anonymous Jun 11, 2008
    I have the same problem with my refrigerator. The freezer works fine,but my frig wont stay cold. I turned my frig down to the lowest setting and it only cools to 50 degrees.
  • carolarm Aug 04, 2008
    Refrigerator is not cooling, but the freezer is ok. I turned the timer of the fridge of and unplugged the refrigerator.
    Plugged again and turned on the timer to the cooler temperature. The freezer fan is working but it seems that the fridge is not turning on.
    It could be the compressor?
Defrost problem. either bad timer, bi-metal or heater.
Posted on Mar 25, 2008
  • 291 Answers
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Posted on Aug 27, 2007
SOURCE:
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Unit was making noise. bottom freezing, top meling, no cold air blowing into the refigerator from freezer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Amana Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
