How do i take apart an old timer knife - Televison & Video
    Top Expert:
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Jul 09, 2013
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
Tip
SHURE E3g EARPHONE PROBLEM
IF YOU HAVE THE SAME PROBLEM WHAT I HAD WITH MY 3 YEAR OLD SURE E3g EARPHONE THAT ONE SIDE IS NOT LAUD ENOUGH......<br /> I DID TRY ALL THE CLEANING WITH THE PROVIDED TOOL BUT ALL DID NOT HELP.<br /> I DID USE A KNIFE AND DID SLOWELY FOLLOW THE GROVE ARROUND THE TIP OF MY BAD EARPHONE. AFTER A FEW MIN. WORKING WITH MY KNIFE IN THIS GROVE I DID FEEL THAT THE EARPHONE WILL COME APART. THE TIP HAS NO CONNECTIONS (ELECTRICAL SPEAKER WIRE CONNECTIONS) NOTHING IT IS JUST THE EARPHONE PLASTIC TIP. AFTER I HAD THE TIP IN MY HAND I USED A NEEDLE AND I GOT A LOT OLD EAR WAX OUT AND MY EARPHONE IS VERY LOAD AGAIN. NOW CLEAN BOTH SIDES AND PRESS THE TIP BACK ON. IF YOU FEEL BETTER USE A DROP SUPER GLUE TO BE SURE IT WILL NOT COME APART AGAIN AND STUCK IN YOUR EAR. I DID NOT USE ANY GLUE.<br /> I HOPE THIS DID HELP YOU TO CONTINUE TO LISTEN YOUR MUSIC WITH YOUR SURE E3g EARPHONE
on Mar 18, 2011 | Audio Players & Recorders
How to take apart a porter cable cordless drill model numbe PC1800HD
first you unplug it then you take out all the screws, if it doesn't open after that. then take a sharp knife like a hobby knife and score around the mold edges and pull everything apart.
Jan 16, 2012 | Porter Cable Drills
I have the # 4001 - 00 timer (other info on timer is TD-1744OG) My timer is being used to turn on and off specific lights for an apartment complex - ie front entrance, back entrance and so on. My...
4001-00 is 120Volt mechanical timer.
I suggest replacing old mechanical time piece with newer electronic time clock with back up carryover.
http://waterheatertimer.org/Boxtype.html
Intermatic EH10 is 120V has power carryover
Tork EW103B has selectable voltage with capacitor carryover
Sylvania SA300 is 120V has backup battery carryover and also has dawn-to-dusk feature
Open link above to see manuals and sellers
Sep 08, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
How to change the timer on WGD5800SW0
First things first, disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the screws attaching the console to the rear of the machine then use a putty knife blade or similar tool to push and release the clips holding the console in place to the top of the machine. Push the putty knife blade rearward under the front corners of the console until the clips are released. Pull the timer knob off then flip the console to access the timer.
Remove the screws securing the timer to the console bracket then secure the new timer in place. Disconnect the wires from the old timer one at a time then connect it to the new timer to prevent messing up the wires.
Push down the console down onto the top of the machine to engage the clips then secure the console back into position.
Note: The timer is part number 3406725.
May 22, 2010 | Whirlpool WGD5800S Dryer
How do you strip insulation form uf electrical wire
I use a sharp knife and slice off the outer covering on each side of the cable. With practice you can "feel" the outer insulation of the conductor and make the knife slide along it without damage. At that point I simply pull the two conductors out of the covering and use my wire stripper to expose the bare ground wire. When stripping the ground, I use a oversized hole on the wire stripper to keep from scoring the wire.
2 conductor is easier to strip than 3 conductor.
here's another
I've never tried tearing it apart. That sounds like it would be hard on the conductors to me.
steve
Dec 13, 2009 | Hardware & Accessories
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Water is plugged by minerals etc in my Hansgrohe kitchen faucet
You will need a flat head or a knife. You sould be able to pry it apart if not they are so cheap, pick one up at walmart, lowes etc. Bring the old one with you. Some of the tread patterns are diffrent
Feb 03, 2009 | Hansgrohe 06649860 Solaris Single Hole...
Lux timer will not ring
Your very old Lux timer has timed out and needs to be retired.
Aug 08, 2017 | Lux Hardware & Accessories
Change my radiator hose
just keep trying I have had to take a knife or screwdriver and break it apart before.
Jun 09, 2008 | 1999 Pontiac Grand Prix
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
