Question about Dishwashers
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Posted on Jul 31, 2013
3 Suggested Answers
SOURCE: Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Posted on Feb 15, 2009
  • 423 Answers
SOURCE: Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Posted on May 04, 2009
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a Kenmore Ultra wash Quiet guard 4 and when it gets done washing, it leaves tiny pieces of food on the dishes. I have used the dishwasher cleaners a few times and started rinsing my dishes till...
This is typical of the two following problems:-
1. You are using no salt or too little salt. Even if you use tablets/powders with a built-in salt action, in some areas the water supplied by the mains pipe still requires supplementary salt.
If you already use salt, then turn up the dosing control a step at a time until the problem goes.
2. The heater element in the dishwasher has failed and so every wash is a cold wash. Heat is vital to enable a dishwasher to operate correctly. Failed heating elements are very common and if you can get the spare part then replacement is straightforward for any competent person; I rarely find that they take more than 20 minutes to replace on most brands. But as you are mixing water and electrics it's definitely NOT a job for a novice.
Aug 08, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
