Question about Continental CE72096 Air Conditioner
Manual will not blow cold air , what should I do to fix my problem ??
No heat blowing cold air
Heater blowing cold air? - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan.../233563-heater-blowing-cold-air.html
Nov 5, 2006 - 15 posts - ‎6 authors
... it idle, all guages normal, heater on HOT and HIGH, it blows cool air. .... thatNissan put out for some reason (I have no idea where it went to, ...
How To Fix Your Car's Heater - YouTube
? 3:03
https://www.youtube.com/watch?v=bmmn4ON_t0c
Nov 26, 2009 - Uploaded by Scotty Kilmer
... Scotty Kilmer shows how to fix your car's heater for those coldwinter ... How to Diagnose and Fix No Heat Issues - Also a Demonstration on ...
maxima blowing cold air while idling - Maxima Forums
maxima.org/...maxima.../599527-maxima-blowing-cold-air-while-idling....
Sep 21, 2009 - hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving. ...Not sure whats involved in a heater core for the Max, but I had to pull the ...
Jan 15, 2016 | Halonet 95-99 NISSAN MAXIMA / 96-99...
MY REAR HEAT WANT BLOW NOTHING BUT COLD AIR OUT WHY IS THAT & HOW DO I FIX IT
Its supposed to blow out only cold air. I wondered the same thing when I purchased my 2001 durango and then I read the owners manual and it says it is only supposed to blow cold air out in the rear of the vehicle.
Dec 12, 2012 | 2001 Dodge Durango
Front a/c blows cold air but back is blowing hot air
Could be low on freon, a faulty expansion valve on the rear system, or other issues. Can you tell if the rear ac lines are hot and cold ?
Aug 04, 2012 | 2001 GMC Yukon
I have a 2007 subaru legacy. it has 17000 miles im having a problem with heating.. when i turn the heat on only driver side blows hot. the pessenger side blows cold even when i turn it on to the winshield...
The air is mixed and routed inside the dash by some flaps. In your case the flap that regulates the mixing of hot and cold air for the passenger side is broken or stuck in the cold position.
The only way to fix that is to remove the dash , access the air system and fix the flap.
Feb 07, 2011 | 2007 Subaru Legacy 2.5i SE Sedan
Heater not working it is blowing cold air at all times is there a
Heater blowing cold air until I get on the interstate, then it works; however, when I stop at lights it starts blowing cold air again. The temperature gauge will be in the middle but the car will still be cold until the car starts moving.
Nov 14, 2009 | 2002 Jaguar X-Type
Continental CE72096 Air Conditioner Logo
21 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Donni Steen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
