Am I doing something wrong or is that reading correct or do I have a problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model air conditioner? What reading?
Posted on Jul 08, 2013
  • s_vega30
    s_vega30 Jul 09, 2013
    The low pressure reading is giving me over 100psi
  • rayluv2269 Oct 24, 2013
    Wel depending on type of refrigerant r22 is high on blue gauge and low for r410a
I have the settings correct but it still doesn't zig zag correctly??? what could be wrong???
try a new needle
could also be something wrong with the cam that does the zig zag stitch
would be a good idea to have the machine checked to see if there is something wrong with the cam
Mar 09, 2016 | Husqvarna Viking Emerald 116 Sewing...
The camera has a message that the Media Dial is in the wrong position and it will not do anything.
Read the manual, locate the media dial and set it to the correct default position.
If camera refuses to operate, then there is something wrong with unit.
Aug 31, 2015 | Cameras
Error codes p0108/p0203/p0303 what are they
what engine, cant fix,them not knowing that.. so what engine is there, opted day 1.
they are failed ECU/PCM tests.
thats correct the light means the EFI (or other parts) needs service.
it means SOMETHING IS WRONG.
if you had the FSM , and read the page under P0108 youd
see the book telling you what the test does, and how to isolate
that problem, to the CAUSE.
the PCM does not EVER know cause, only what tests fail.
see?
303 is cylinder 3 misfire.
108 means the Baro MAP sensor is reading too high
203 means injector 3 , is reading wrong.
Id first check injector 3 , for connector fell off or wire damage there.
or pins corroded
then disconnect it and measure the injector coil resistance.
infinity is a blown coil.. it will read the same as the other 3,
if all read 10 ohms then that is correct. (im not locking up the spec here, you can RTM , FSM or alldata.com and see it)
203 is a hard fail. i do them first.
the map might read wrong do to a dead #3 cylinder
and #303 misfire, id bet is a victim of bad injector #3
Feb 02, 2014 | 2002 Jeep Grand Cherokee
My player has audio but no video
try to see if there is something wrong with the cable .. or select the correct input on the monitor or tv .. Also make sure your player is capable to read the format of the files .. Not all video files can be read by all players ..
Jan 29, 2012 | Televison & Video
98 pontiac trans am changed oxygen sensors pre catalytic per code from service eng light post catalytics were changed in nov 09 still does not run properly spits and sputters on takeoff and while driving...
just because the o2 readings are off doesn't mean its bad, its a sensor and it reading something something amiss in the exhaust, you're problem lies elsewhere, could be plugs, fuel delivery , coolant in the exhaust, among a few ,check the plugs for possible misfiring, the deposit color should all be the same, light or tan deposit indicates coolant, whille the plugs are out do a compression test,
May 28, 2010 | 1998 Pontiac Firebird
MY NDS lite wont read DS games but will read
there might be something wrong with the card reader. Or something wrong with your card. Try cleaning them with something (not a tissue, that will make it worse). If that doesn't work, it's probably something wrong with the internal wiring and such, so there's not too much you can do about it
Jan 17, 2010 | Nintendo DS Lite Console
Wave receptor watch is on the wrong time.
Follow this link and get instructions:
http://world.casio.com/wat/download/en/manual/
This manual can be more helpfull.
Rate me, please.
Mar 17, 2009 | Casio Watches
Can't read what is scanned
What you need to do is get some cleaning solvent from a Computer Store and clean the class. If this does not correct the problem then try uninstalling and reinstalling the drivers. It sounds like your screen may just be dirty. If you can print it and then scan it that is very perculiar. Try this and let us know if that fixes the problem.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Car chugging
To determine what's wrong, u need to have the codes read. If the light is coming on, it is a signal that something is wrong w/ the emissions system. A code is stored in the cars computer that will indicate what the problem is. Most parts stores will read the stored engine codes for free. They plug a scan tool into a port under the dash to retrieve the code(s). Write them down, and ask what u should do to correct the problem. If u have any further questions after that, u can post them here. Let me know how u make out.
Dec 15, 2008 | 2003 Kia Sedona
Heating & Cooling Logo
344 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
