Question about Mitsubishi WD-65738 DLP TV
Computer hooked to TV through stereo
I have everything hooked to my stereo including a computer and then out to the HDMI 1 on the TV. When I try to play a game on the computer I keep getting HDMI 1 and the speaker symbol flashed on the top left of the screen and when it does this it causes my game to minimize? I tried hooking the PC direct to the TV via HDMI 2 and naming the slot PC and it does the same thing, any ideas on how to stop this?
    Champion:
  • 247 Answers
A computer is a versatile gadget its meant to format anything thats comes to its screen this is done by sophisticated drivers that will say 'think ' and place anything in a smart manner this is the way its made so u cant do anything about it unless u have a full screen option, hit full screen to enlarge your picture
Posted on Jul 11, 2013
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
  • 38 Answers
SOURCE: philips 1080i xbox 360 hook up
you need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Posted on Oct 27, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
diths_kri
  • 67 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Posted on Jan 07, 2009
doin12volt
  • 233 Answers
SOURCE: connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Posted on Jan 12, 2009
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
How do I hook my sylvania model number 6432GG TV to my ASUS laptop model #D550MAVD801?
The only inputs tho the TV are cable in and AUDIO / VIDEO in.
You can use 'stereo patch cords', to plug into the tv. Check with your local computer store to see if you can find adapters to plug into the computer and change to RCA jacks.
All of that means, you probably can't.
Dec 04, 2014 | Sylvania 6432GG 32" TV
GET MY COMPUTER TO SHOW VIDEO
If you did connect the computer to the tv with a HDMI cable, you have to look there. HDMI also protects giving through copy protected content. Please read everything about HDMI and digital rights.
Oct 29, 2014 | Audio Players & Recorders
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
I want to know how to hook up my PC to this TV as a monitor. The manual says to use HDMI 1 port and the DVI port on PC. Do i need to get adapters to make such a connection
an hdmi cable will do then hook up to hdmi port 1 and on tv select that input and it should work. of course the hdmi cable has to be hooked up to hdmi input on computer
Jul 08, 2012 | Magnavox 32MF339B 32 in. TV
I have a Philips 47" flat screen it has HDMI
First of all you must check that your laptop supports a protocol called "DHCP" over DVI. Otherwise you are chasing your tail. This information will probably be in the manual or available online. DHCP is a special handshake protocol for HDMI and your television and computer will not talk to eachother without it. If you find it to be compatible you need to lock down which input on the TV it is. Plug something in via HDMI and verify you see it. Then unplug it and plug your computer into this port. You don't want to be flicking through inputs trying to find it. Also, hook up an external monitor to the laptop and figure what needs to be done to display on it. Then try the television. My guess, though, is that you won't find DHCP compatibility if it is an older laptop. My best advice is to buy a Playstation 3 and watch Netflix with that. Otherwise you'll need a different way of hooking up which might include buying an expensive converter box and/or watching poor quality video.
-Good luck
Apr 24, 2011 | Philips Televison & Video
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
I have a macbook and want to hook up to my dynex 24 inch tv. I am successful using (mini dvi to dvi to hdmi) connection to the tv receiving great video. My problem is that I have no been able to get audio...
Your mac would have to have a fully hd compliant mini port. To be honest I havent even checked to see if any do. Then you would want to get a mini video port to HDMI adapter. If you don't have one of the newer Intel mac then chances are you cant do sound through that port, which is what your tv is looking for on the hdmi port.
Easiest solution is to hook your headphone port on your laptop to a stereo or some decent computer speakers, which usually sound better than tv speakers anyway.
Jan 08, 2010 | Apple Computers & Internet
I want to hook my vizio tv up to my computer what cords are needed?
Likely standard VGA ... unless you have an HD card in your computer ... I got one for mine in order to play blu ray after I bought a blu ray drive for my computer. In that case I needed an HDMI cable. HDMI passes both the video and the audio, otherwise you need to connect also a stereo audio cable between your sound card output and the tv input, close to the computer VGA connection.
So:
1.) http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4ADBF_enUS255US256&q=SVGA+Cable
2.) http://www.newegg.com/Product/Product.aspx?Item=N82E16882021054&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Audio+/+Video+Cables-_-Rosewill-_-82021054
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
When i hook up my hdmi cable box how do i get my stereo to run sound..? or can i..?
HDMI is audio and Video in the one cable, if your stereo has HDMI in and out you can run it from your box into your stereo then into your TV, but only if everything is supported by your componets, I would suggest, HDMI into your TV, then from your box, stereo or optical into your stereo, by just using RCA cables. ALSO remember with audio compontes, more is MORE, more cable better quality (not length but size)
Jul 05, 2009 | JVC LT-42E478 42 in. LCD Television
Mitsubishi WD-65738 DLP TV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
