Question about GE DSXH47EGWW Electric Dryer
Dsxh47eg0ww I am wondering if I need to replace the control panel of my GE electric dryer, model number dsxh47eg0ww. We have cleaned lint filter inside by removing trap and vacuuming way down in, disassembled and cleaned ducts... not a ventilation issue. It doesn't have a consistent error code. Sometimes it will start for a minute, then turn off and all the lights on the right side of panel will beep 6 times, other times it will run for 5 minutes then beep 3 times. We ran a test for an error code, then it beeped 9 times and the start button blinked 5 times after that, but that error was not even an option. Wondering if it sounds like a control panel issue and if a 5 year old dryer would be better off replaced than repaired. Replacement is about double the cost of new control panel. How long do these dryers last on average?
  • GE Master
  • 15,557 Answers
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Posted on Jul 08, 2013
  • Krista Hosler Jul 09, 2013
    Took your advice and ordered the control panel...hope it works! Thanks!
kevin000
  • 1847 Answers
SOURCE: the start button on the
i feel it is loose connection issue,
Posted on Jun 08, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
  • 3 Answers
SOURCE: DBXR463ED1WW GE Dryer Runs for Hours
on which setting are you running it. If you are running this on the timed setting then its obviously a faulty timer. Sounds to me though that you are running it on its automatic cycle. If this is the case it could be a couple of things. Somewhere on ur beast there is a moisture sensor, this is what advances the timer and tells it to stop. This may be faulty or it could be that ur vents are indeed clogged which would trap the moisture in and result in the long dry times. The simplest way to go about this one would be to clear the air flow and see if the problem persists.( this means pulling out the dryer clearing all the vents, if using the flexible ones make sure they are not binding up while setting dyer in place. Also if there is a vent that runs through the wall as well you can clear this by removing exterior vent). good luck
Posted on Feb 20, 2009
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
Maytag317
  • 1136 Answers
SOURCE: GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
Posted on May 25, 2009
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
GE gas dryer DSXH47GGWW- starts fine and begins to heat up then shuts off with a message that the lint filter needs cleaned. The lint filter has been completely cleaned and vacumed inside, outside and...
With no lint anywhere around the dryer the thing to check if havent already is the venting itself to see if outside it is blowing and not restricted or blocked
The control is sensing poor air flow and throws up the "clean filter" when air flow is restricted all be it from the filter clogged, or blocked/restricted vent
Gene
Aug 25, 2011 | GE Dryers
Dryer will not come on
is it gas or electric and it would help if you sent the model number,if the filter is on top,unplug the dryer,pull it out,take off the vent line and remove the back panel,to the right of the duct that the lint filter slides into and near the bottom you'll see a white thermal fuse part number 3392519,pull at least one of the wires off and with a meter see if it's open,if you get no reading it's open or bad and has to be replaced.if the filter is inside remove the bottom panel,pull out the lint filter,remove the duct that the filter slides into and on the top right hand side you'll find the fuse there,it might be a 3390719 but you can check it,again pull a wire off and check it with a meter,while you're in there clean out the duct that the filter slides into and vac out where the motor is,then if the vent line is a long run blow it out with a leaf blower,the dryer is running to hot from all the lint and if you don't clean it the fuse will pop again.if that's not the problem send the model number so i can see what's in your dryer
Feb 18, 2011 | Kenmore Dryers
Exhaust plugged inside dryer How do I get the plastic filter that holds the lint filter in place off?
you will need to remove the front panel to access the bottom of the lint trap and blower housing
Jan 24, 2011 | GE DCVH515EF Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
I have a ge dryer model DSXH47EG0WW which turns on but has no heat. I have checked and re-trip the breaker cleaned the vent and back of dryer but still no heat. I was even able to open the back panel and...
Verify 240vac at dryer. If the element is not broken and the power is present then you will ave to trace out the circuit. Check the termostats and the timer contacts, remember you are working around 240 volts and if you do not have the training and skills it would be better left to a technician.
Eric
May 20, 2010 | Dryers
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
Ge DRYER dpgt750EC2PL back wall of drum gets very hot. Occassional smell as if something starting to burn. How do I open the top lid to get inside to find out problem
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Mar 15, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Electric Dryer
that is one thing I have learned, don't take anything apart that you dont need apart. Clean with shop vac-it will suck it out.
Jan 04, 2008 | GE DWXR483EBCC Electric Dryer
I need to clean out the dryer duct and inside.
send me a model number it is found on the back of the control panel if it is a floor model. if it is made to stack check in the door. Usualy not much lint gathers in the controls of a floor model.
Sep 16, 2007 | GE DBSR453EBWW Electric Dryer
GE DSXH47EGWW Electric Dryer Logo
355 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
