Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Water dripping at top of refrigerator compartment
Hi, I just inherited this top freezer model and it just started dripping water from around the light at the top of the compartment. I assume this may be a problem with the defrost cycle draining. Can anyone tell me what I should do? Really appreciate the help.
Re: Water dripping at top of refrigerator compartment
Try to blow air through the defrost drain hose from the bottom of the fridge to make sure the line is clear for defrost water to drain.
Posted on Aug 27, 2007
0 characters
3 Points
Why water drips from top of refrigerator to top shelf
With a model number I could answer this problem you have. I assume you have a top freezer and the drain system is clogged. This will cause water to drip into and on the shelves within the compartment below. The problem is in the freezer section. Please if this information is misdirected, get me more information as to the model number and manufacture of the unit in questioned. Thnaks and good luck
Oct 10, 2014 | Refrigerators
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Water dripping into fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
May 28, 2010 | Frigidaire FRT21H8 Top Freezer...
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Dripping water from freezer compartment into refrigerator compartment
Hi, Could I get the model #? The defrost drain is plugged and I can get you through this with the #
Some newer models need an after market drain heat strip added.
May 29, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
190 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
