Question about Dell OptiPlex 380 MT Desktop Computer (Intel Celeron 450 160GB2GB) (BO1S12FD2)
NETWORK ADAPTER HOW DO I GET AND INSTALL NETWORK ADAPTER DRIVER
  • Dell Master
  • 27,725 Answers
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
Posted on Jul 08, 2013
How can i connect wireless network . I am geeting Error network adapter driver not installed
The error message states that the drivers for your network adapter are not installed. You can either use a dell drivers and utilities disc to install the network drivers or can go to http://support.dell.com/support/downloads/ and can select your computer model and entering your service tag number (located on desktop) and can install drivers.
Good Luck!
Jul 16, 2010 | Dell (d5516) Network Adapter
Every single driver under the "network adapters", ...
Try to re-install the drivers.
Firstly, right click on every option under network adapters and select uninstall and later click on scan for hardware changes. It should re-install the drivers if they are present in the operating system.
Secondly, if you have a driver disc for your network adapter than try to re-install the drivers
May 16, 2010 | Computers & Internet
Dell inspirion network adapter driver corrupt. Tried downloading drivers from dell and problem still exist
Try to remove the all the installed drivers by uninstalling the Network Adapter. Then plug it and let windows initialize it for installation.
Jan 05, 2010 | Dell Ethernet Card Network Adapter
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
How do I install my Belkin F5D7051 wireless adapter without the installation CD?
To install the adapter you will definately need a disc. because the adapter will not work without the Drivers. Drivers are very important for the adapter. One more thing that if you have WIN XP or VISTA then you don't need the set up utility but still you need the drivers for the adapter.
If you do not have the disc. You can download the drivers from the manufacturer's web site and install the drivers for your adapter.
Click her for more info about networking
Oct 08, 2009 | Belkin 802.11g Wireless Desktop Network...
Network adapter not working
your network adapter driver is not installed. Install it and then have a look . open device manager and in that look for network adapters if u can see there then ur driver is installed successfully..
Aug 26, 2009 | Compaq Network adapter
Everytime I try to connect using the WUSB54GSC it
You need to Update the Drivers for your Wireless Adapter...Download the Drivers from here
After downloading the drivers you need to unzip the file...After you unzip the file you should un-install the adapter drivers/software from Programs menu...Leave the adapter connected to the PC and reboot your computer...Once the computer is rebooted you should see a message "Found new Hardware"...Select the option Install it from a specific location and click Next, then select Include this location in Search and browse to the place where you have unzipped all the files and select the Driver folder and click O.k...Then click Next and it should install the adapter drivers...
NOTE : This installation doesn't install the software(Linksys Monitor)...
Once the Adapter is installed, Click on the Start button >>> Control Panel >>> Network Connections- Right click on the "Wireless Network Connection" icon and select "View Available Wireless Networks"- If you see your wireless network in the list, highlight it by 'single' clicking on it- Now click on the 'Connect' button below- If your wireless network is secured, it would ask you to provide the network key- Provide the wireless network key and confirm it again in the confirmation box and click "Connect"...It should connect to your Network and Internet...
Jun 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Yellow exclamation mark over the network adapter- 6To4 adapter. When I uninstalled and restarted my computer the adapter was not reinstalled. Sony laptop with Vista 32 OS.
the yellow exclamation mark indicates that the driver is not installed... run the installation disk once again install the adapter .. if unable to install with cd then, right click on the adapter from device manager and click update driver and manually update the driver ... it should work
Apr 16, 2009 | Packard Bell 1580509280 Network Adapter
Network problem in COMPAQ presario V3000
There are two ways to install the driver:
Install the driver using the wizard.
Forcely install the driver
Steps:
Right click on the icon that has the yellow mark
Click update driver
Choose install using specific location
Open the driver location
Then proceed to the Installation
Last restart the computer and check if you got still the yellow mark.
Note: Check the operating system and the adapter maybe there is a compatibility issue.
Mar 01, 2009 | Compaq Network adapter
Usb network adapter
you network adapter either is not installed or the OS recognized it as a "generic adapter" and apply an appropriate driver for the said hardware. this is good but sometimes the windows just apply the nearest driver close to what is you driver...
if you network adapter is brand new chances are that you still got the disk came with the package and just uninstall the window's xp driver and reinstall it. if you dont have the disk just look at the website of the said adapter.
solution:
if you are using windows xp
1. click control panel
2. click the icon "system"
3. at the hardware tab click the "device manager" and look for the network adapter branch
4. if you can see a network adapter installed right click it and click uninstall...
5. reboot and let them window automatically search and reinstall your adapter.
6. if you the windows don't automatically install it, go back to control panel and click "add hardware" and install the hardware manually
hope this help...
Jan 19, 2008 | Computers & Internet
Dell OptiPlex 380 MT Desktop Computer (Intel Celeron 450 160GB2GB) (BO1S12FD2) Logo
74 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
