Question about Dishwashers
Dishwasher malfunction MOST OF THE TIME it shuts itself down before fully filling with water - SOMETIMES it doesn't shut down until the minute the wash pump starts - SOMETIMES it washes for 10 or 20 minutes before shutting down - SOMETIMES it will even run a whole cycle, BUT it doesn't open the soap dispenser door - tried doing a diagnostic run but after it turned on all the lights on the panel it started to fill with water and shut itself down......... HELP
  • Richard Blount Jul 10, 2013
    It's a Whirlpool Quiet Partner II
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Posted on Jul 09, 2013
3 Suggested Answers
SOURCE: dishwasher blows circut breaker and shuts down about 5 minutes into cycle.
possibly your heater is shorting.
Posted on May 14, 2008
  • 6 Answers
SOURCE: dishwasher shuts down during wash cycle
Could it be a thermostat proble?
Posted on Oct 10, 2012
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
What is the correct water level in a kitchenaid dishwasher?
There is a float inside, the float should be nearly to the shut off position when the dishwasher is full. If it isn't add water until it's about 2 inches deep, or within 1/2 inch of overlowing the front of the dishwasher. Run a cycle and see if your dishes are cleaner. If so, then the likely problem is with the water pump. Take this off, clean all screens and soak in Lime-Away or something similar and reinstall. In all probabilty if the dishwasher doesn't fill, there is dirt in the pump screen or buildup in the pump itself. If this does not fix the water level, then a new pump may be necessary (around $20-$40 on eBay).
Apr 15, 2012 | KitchenAid Dishwashers
Water only dribbles out of lower spray arm during cycle and spray arm doesn't turn. checked filter, water lines etc. If it's a motor or pump that needs to be replaced, how do I get to it?
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 03, 2011 | Bosch Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Dishwsher doesn't get disher clean
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Hoover 24 in. DT999 Free-Standing...
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
Water Inlet Valve
Aug 03, 2011 | Dishwashers
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
The machine will not refill, I did the water softner yesterday and have been having problems since. Now the machine will not fill at all and turns itself off.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 18, 2011 | Dishwashers
Bosh dishwater does not fills with water: seems it shuts down!
you have a leak probably from circ pump. there is a float in the base which when lifted by water, shuts everything down and turns on the drain pump
Jan 29, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
