Question about Haier CPRB09XC7 Portable Air Conditioner
Why is my window ac in the bedroom suddenly filling up and splashing water from the top?
I'm not sure of the window model, I've only had it for about 4 years. It has never happened before, but now it sounds like it's filling up with water and spraying out as the fan blades go through it. I don't think thereis a drain hole in the bottom. I've never had to drain it before Help!
  • 163 Answers
SOURCE: Water dosent drain
well lets work with it becouse that the one you have..first let me tell you dont make that hole becouse the water that remaing in the tray is use to cool down the condenser and beleve me its a good idea..its not supouse to condese more water thant he can evaporate..but try to screw a littel bit more the two screw in the back of the cabinet to down the cabinet 10 degrees more to see if that help you...good luck
Posted on Aug 03, 2006
shastalaker7
  • 1515 Answers
SOURCE: The model # of my
Hi, normally they have a very small gutter type track indoors below the indoor coil. It should have what is called weep holes at either end for the condensation to run off. I have seen this problem a lot on window units, and some people have had to go as far as drilling there own holes to get there to drain, which is crazy. Check the front very good for a trough to catch the condensation and for these weep holes I am talking about. Please let me know the out come.
Sincerely,
Shastalaker7
A/C Contractor
Posted on Jun 06, 2011
  • 1033 Answers
SOURCE: I have a haier window
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
Posted on Jun 07, 2011
  • 4736 Answers
SOURCE: Hi! My AC
If it's leaking water and it's an electrical appliance. Water & electricity don't mix, do they? So, first turn the unit OFF and unplug it from the wall. But, not if you're standing in water.
Here's the problem: The plastic tubing that's supposed to drain the water into the bucket is clogged and it's draining it onto the floor.
Remove the water bucket and look up into the bucket cavity. You should see a small hole or tubing. That's the drain to the bucket. Using an 18" long plastic Zip Tie, appropriately sized to fit that hole or tube. Carefully insert the Zip Tie into it and continue to insert it, until you reach a bend in the tubing. You must gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then, slowly pull it back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow. If you don't have a Zip Tie & don't want to go out and buy one, you may use something similar. But, NO wire coat hangers.
Hope this helped you solve the problem.
Posted on Jul 07, 2011
  • 4736 Answers
SOURCE: why isn't there drain holes in bottom of
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
Posted on Jul 23, 2011
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
Why does my bleach dispenser cup fill up with water every time I do a load of laundry?
I agree with grady709 about the plugged inlet lines, I had water left in my Samsung front load all the time and made sure the machine level and nothing wrong with venturi. I suddenly had water leaking from somewhere instead and when I took the top off I could feel the line swell up and leak at the fitting. Hose still leaked after replacing. Put a drill bit by hand down the nozzle where the hose clamps on and it was plugged up and also the bleach line was plugged up, also inside where the tray goes there is small holes in the top where the water sprays out can be plugged. Worked for me. Live where the water is hard.
Nov 24, 2012 | Samsung Washing Machines
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
Hi, I've got a Hotpoint RLS175 fridge which doesn't cool. At first there was a buildup of ice on the rear of the fridge compartment but now it doesn't cool at all. At first I thought it was a...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 20, 2011 | Hotpoint RLA50 Refrigerator
My refrigerator temperatures suddenly changed from 40 degrees in the main compartment to 8 degrees and -30 in the freezer compartment. I'm unable to adjust the temperatures back to original settings. ...
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Sep 05, 2011 | Refrigerators
LE error cam e on and I've drained the water, cleaned the filter, etc. I also unplugged it to reset it. It fills the water and starts to spin, but it suddenly stops and gives me the LE error once again...
If your washer is an LG (unfortunately you have not said) on most 'LE' stands for 'Lock Error'. If so there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of spinning, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 29, 2011 | Washing Machines
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
Jun 17, 2011 | Keurig B60 Coffee Maker
Need to know if I can connect a drain hose/tube to my air conditioner model # FAX054-P7A1. I'm having a problem with water collecting in the window sill/track
Hello, the first thing is make sure the AC is tilted a bit in the window, if it is level the water will collect toward the front of the unit and drip inside. Second if there is a drain hole on tne unit then you can connect a hose to it and let it drain. However if there is no drain hole then the unit uses tne fan blade to splash the water on the condenser and since the condenser is warm/hot it will condense the water.
Jun 08, 2011 | Frigidaire FAX054P7A Wall/Window Air...
Haier CPRB09XC7 Portable Air Conditioner Logo
19 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
