Question about Tools & Hardware - Others
How to put dry wall on plaster walls?
I need the cheapest way to fix my walls in my living room and fast...?
  • 2 more comments
  • Anonymous Dec 10, 2013
    I personally wouldn't do it myself, but I would check out commercial painting. They could do it for you and save yourself the headache.
  •  Steve
    Steve Apr 13, 2014
    if you want to actually fix the wall, scrape everything you can off with a 6" drywall knife then solid float with drywall mud.
  •  Steve
    Steve Apr 13, 2014
    But Personally I would just hand some new 1/4" drywall over it or some cheap paneling.
  •  Steve
    Steve Apr 13, 2014
    Hang, not hand... typo.
  • 15,557 Answers
If you want to use drywall you can get 1/4 inch drywall and lay it over the plaster, You can anchor it to the studs under the plaster or you can get 1x2 furring strips and anchor those with glue or screws and then anchor the drywall to those. If you are going to do anything with the ceiling, you should do it first. Then the walls. If you are going to use drywall on the ceiling then you have to take the false ceiling out. Also you have to use a thicker drywall on the ceiling. You could leave the ceiling lattice intact and just put in new panels.
Posted on Jul 08, 2013
We Eastern Ceilings and Partitions provide the cheapest and best way to plaster your bedroom walls. please contact us Plastering Services in Sydney From Eastern Ceilings Partitions
Posted on Feb 18, 2016
Fixing plasterboard to bricks ?
Google GORILLA CONSTRUCTION ADHESIVE
Nov 10, 2016 | Cars & Trucks
How to put a raw plug into a plaster wall?
It's actually quite easy, but a few simple rules need to be followed. The drill size will depend on the size of the plug to be used. The type of drill bit will depend on whether it is a wall with plaster on it or plasterboard, which will have a cavity behind it. If it is a solid wall, use a masonry drill, on hammer setting if you have it. For a plasterboard wall a wood or HSS drill bit will do the job. Once you have drilled the hole, push plug in as far as you can, then tap it flush with a hammer. Job done.
May 20, 2014 | Hand Tools
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
Water damage to walls and ceiling in a building built from 1920 I scraped it down to bare wall now I'm interested in ideas in fixing the damage the walls are plaster. Thank you.
You can go to Lowe's and ask them for some wall plaster,tell them what your doing and they will get you the right kind and you will also need a putty knife to spread,and some sand paper,it will get real dusty when your sanding and it will go every where,use safety glasses,and a dusk mask and cover your hair.
Nov 02, 2012 | Computers & Internet
I have mold on a plaster wall - how do i fix mold on a wall with mold
Clean the wall with bleach and then paint the walls with anti-fungal paint.
If this room is a bathroom then install an exhaust fan to draw out the moisture when you take a shower.
Oct 28, 2012 | Dell Inspiron E6550 Notebook
My house has a hard plaster ceiling in the living room. We would like to add lighting hung from the ceiling, but that would have a 2 or 3-prong plug that we could run across the ceiling and down the...
There is a product called Wiremold, a plastic channel that hides and protects wiring. It can be painted after installation to match wall color. Available at home improvement stores.
Jan 15, 2011 | Kitchen Appliances - Others
One tile in the first row up from the tub fell out and the wall behind where the tile came out is soft and not ridged at all to glue the tile back in place the wall is plaster nd lath im letting it dry...
Wetted plaster often dries out like dry sponge cake. When dry try a spray of 25% pva solution. This soaks in and solidifies and stabilizes the plaster.
Whatever you do keep it dry from further water
Dec 01, 2009 | Home
Tools & Hardware - Others Logo
267 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
